- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] debugging facilities
- Date: Wed, 12 Mar 2014 19:25:41 +0400
Hello, Dmitry.
Currently, debugging in proof session with little reduction steps
with or without coq-breakpoints is more or less enough.
What I asked about from the beginning: possibility to print text while evaluating term.
In form of ad-hoc macro or function with side-effect similar to trace from Haskell.
Maybe it is very easy to implement such function with OCaml plugin.
Example:
P.S. (Haskell, Debug.Trace) trace :: String -> a -> a.
Example:
Definition double (n : nat) :=
match n with
| S n' => TRACE "S branch" (S (S (double n')))
| O => TRACE "O branch" O
end.
Eval compute in double 1.
(* S branch \n O branch \n 2 *)
Sincerely,
Kirill Taran
Kirill Taran
On Wed, Mar 12, 2014 at 5:09 PM, Dmitry Grebeniuk <gdsfh1 AT gmail.com> wrote:
Hello.
Please describe what kind of tracing/debugging
you need. Small example would be the best.
As for cbv, it's not mandatory. You can use
other tactics to reduce expressions: simpl,
compute. Also you can reduce expressions
under "breakpoints".
- [Coq-Club] debugging facilities, Kirill Taran, 03/12/2014
- Re: [Coq-Club] debugging facilities, Cedric Auger, 03/12/2014
- Re: [Coq-Club] debugging facilities, Kirill Taran, 03/12/2014
- Re: [Coq-Club] debugging facilities, Dmitry Grebeniuk, 03/12/2014
