- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Coq cannot find ML modules
- Date: Thu, 13 Mar 2014 12:58:24 +0100 (CET)
Hello,
I have a problem with Coq not finding ML modules in the loadpath. Suppose I have a folder [foo] with an ML module [bar.cmxs] and a Coq library [baz.vo]. If I lauch Coq with [-R foo Foo] then change the current directory with [Cd ".."], I can load the Coq library with [Require baz] with no problem. However when I try to load the ML module with [Declare ML Module "bar"] I get the following error:
Error: File not found on loadpath : bar.cmxs
What am I missing? Note that this problem does not appear if I don't change the current directory with [Cd ".."].
Thanks,
Ali Assaf
- [Coq-Club] Coq cannot find ML modules, Ali Assaf, 03/13/2014
