- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Controlling typeclass instance priority
- Date: Sun, 23 Mar 2014 14:28:36 -0400
Hi,
I would like to know if there is a way to register a hint in the typeclass database so that it gets called before [exact ...] for things added to the context. For example:
Class A : Type := {}.
Axiom a : A.
Hint Extern 0 A => exact a : typeclass_instances.
Section bad.
Variable b : A.
Goal True.
pose (_ : A).
(* I want to see [a], not [b] *)
The reason I want to do this is to make it more pleasant to work around universe inconsistencies in a development version of Coq.
Perhaps I should submit a feature request to allow negative hint priorities?
Thanks,
Jason
- [Coq-Club] Controlling typeclass instance priority, Jason Gross, 03/23/2014
