- From: emilioga AT cis.upenn.edu (Emilio Jesús Gallego Arias)
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Injection on arguments of type Prop.
- Date: Tue, 25 Mar 2014 09:43:34 -0400
- Cancel-lock: sha1:DEa8JCwXcDBIXFrTddHq1gSRt6M=
Dear coq-club,
What is the reason why the injection tactic ignores arguments of type
Prop?
Aren't constructors always injective?
Would it make sense allowing it again?
For instance, this restriction makes the inversion tactic less useful if
your definitions contain objects in Prop.
Injection over Prop arguments can be enabled by adding back InProp at
tactics/equality.ml:566, following the comment there.
[Unfortunately the change is not fully backwards-compatible. Coq build
broke at QCanon.v, but a one liner fix allowed it to finish?]
Thanks!
Emilio
(* Example of injection failing on prop arguments *)
Variable p : Prop.
Inductive K : Type := K1 : p -> K.
Lemma K1_inj (n n' : p) (H : K1 n = K1 n') : n = n'.
injection H.
(* fails with:
"Error: Nothing to do, it is an equality between convertible terms."
[The error msg seems bogus BTW]
It is easily provable:
congruence.
(* f_equals also works *)
Qed.
- [Coq-Club] Injection on arguments of type Prop., Emilio Jesús Gallego Arias, 03/25/2014
- Re: [Coq-Club] Injection on arguments of type Prop., Ryan Wisnesky, 03/27/2014
- Re: [Coq-Club] Injection on arguments of type Prop., Eddy Westbrook, 03/27/2014
- Re: [Coq-Club] Injection on arguments of type Prop., Arthur Azevedo de Amorim, 03/27/2014
