- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Coq IDE Comment Bug
- Date: Fri, 11 Apr 2014 15:44:42 +0200
If I remember well, comments can also be nested. Ie. if you write "(* foo (* bar *) baz *)", all that will count for a single comment. The "baz *)" part is considered to be commented. This behavior is the same as Ocaml one, but different from C programming language.
2014-04-11 14:49 GMT+02:00 Guillaume Melquiond <guillaume.melquiond AT inria.fr>:
On 11/04/2014 14:32, bhandalc AT tcd.ie wrote:This is not a bug; this is on purpose. ``*)'' is not recognized inside quoted strings, even if such a string happens in a comment. That way, if one puts a well-formed Coq script in a comment, then one gets a well-formed (empty) script, even if there are strings in it.
I noticed a bug in the CoqIDE commenting. If you begin quotations within a
comment that are not closed then the comment fails to close.
Best regards,
Guillaume
.../Sedrikov\...
- [Coq-Club] Coq IDE Comment Bug, bhandalc, 04/11/2014
- Re: [Coq-Club] Coq IDE Comment Bug, Guillaume Melquiond, 04/11/2014
- Re: [Coq-Club] Coq IDE Comment Bug, Cedric Auger, 04/11/2014
- Re: [Coq-Club] Coq IDE Comment Bug, Gérard Huet, 04/11/2014
