coq-club - [Coq-Club] What's wrong with my program? (produces weird term)
  • To: coq club <coq-club AT inria.fr>
  • Subject: [Coq-Club] What's wrong with my program? (produces weird term)
  • Date: Sun, 13 Apr 2014 11:32:59 +0300
Hi all,
With your help to my last questions, I managed to write a function
that produces an infinite data structure, where in every level I'm
holding a a row of Pascal's triangle. Here's the complete program:
Require Import Omega.
Require Import Coq.Vectors.Vector.
Require Import Coq.Vectors.VectorDef.
Open Scope vector_scope.
Require Import Bool.
Require Import List.
Require Import Arith.
Require Import Arith.EqNat.
Require Import Program.
CoInductive triangle_t (T : Type) : nat -> Type :=
| triangle : forall (n : nat), Vector.t T n -> triangle_t T (S n) ->
triangle_t T n.
Definition nth_triangle_aux
: forall T steps_left stop,
stop >= steps_left -> triangle_t T (stop - steps_left) -> Vector.t T
stop.
refine (fix fn T (steps_left stop : nat)
(pf : stop >= steps_left)
(tr : triangle_t T (stop - steps_left))
: Vector.t T stop :=
match steps_left as sl return steps_left = sl -> Vector.t T stop with
| O => fun Z => _
| S n' => fun NZ => _
end (eq_refl steps_left)).
subst. rewrite <- minus_n_O in tr. inversion tr; subst. apply X.
apply fn with (steps_left := n').
rewrite NZ in pf. omega.
rewrite NZ in tr. inversion tr; subst.
assert (S (stop - S n') = stop - n'). omega.
rewrite H in X0. apply X0.
Defined.
Definition nth_triangle {T : Type} (idx : nat) (tr : triangle_t T 0)
: Vector.t T idx.
refine (nth_triangle_aux T idx idx _ _).
auto.
rewrite minus_diag. apply tr.
Defined.
Fixpoint pt_aux h len (v : Vector.t nat len) : Vector.t nat (S len) :=
match v in Vector.t _ len' with
| Vector.nil as v' => Vector.cons nat 1 0 v'
| Vector.cons h' _ t' => Vector.cons nat (h + h') _ (pt_aux h' _ t')
end.
CoFixpoint pt_aux' len (v : Vector.t nat len) : triangle_t nat len :=
match v with
| Vector.nil as v' => triangle nat 0 v' (pt_aux' 1 (Vector.cons nat 1 0
v'))
| Vector.cons h' _ t' as v' =>
let vec := Vector.cons nat 1 _ (pt_aux h' _ t') in
triangle nat _ v' (pt_aux' _ vec)
end.
Definition pascals_triangle : triangle_t nat 0 := pt_aux' 0 (Vector.nil
nat).
Even though I didn't run extracted OCaml code, I checked it and the
code looked reasonable(except keeping length of vectors and using
nats). But for some reason, if I try to run this program:
Eval compute in (Vector.nth (nth_triangle 3 pascals_triangle)
(Fin.F1)).
It takes almost a minute to end and it produces a very weird term:
Warning: query commands should not be inserted in scripts
= (fix nth_fix (m : nat) (v' : Vector.t nat m) (p : Fin.t m)
{struct v'} :
nat :=
match p in (Fin.t m') return (Vector.t nat m' -> nat) with
| Fin.F1 q =>
fun v : Vector.t nat (S q) =>
match
v as v'0 in (Vector.t _ m0)
return
(match m0 as m1 return (Vector.t nat m1 -> Type) with
| 0 => fun _ : Vector.t nat 0 => False -> True
| S n => fun _ : Vector.t nat (S n) => nat
end v'0)
with
| Vector.nil =>
fun devil : False => match devil return True with
end
| Vector.cons h _ _ => h
end
... 650 lines of code removed ...
: nat
I tried using a different strategy to evaluate this term:
Eval simpl in (Vector.nth (nth_triangle 3 pascals_triangle)
(Fin.F1)).
This time it ended fast but resulting term is still equally useless:
= Vector.nth (nth_triangle 3 pascals_triangle) Fin.F1
: nat
Can anyone tell me what's wrong with my code and how can I get a 'nat'
out of simple program? Do I have to run extracted OCaml program for
this?
Thanks.
Ömer Sinan Ağacan
http://osa1.net
