coq-club - Re: [Coq-Club] Existentials and backtracking
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Existentials and backtracking
  • Date: Thu, 17 Apr 2014 19:10:45 -0400
On 04/17/2014 06:12 PM, Pierre-Marie Pédrot wrote:
Well, you're right. Eauto does not really backtrack on evar instances.
This is for historical reasons, as the old tactic engine was not able to
do it properly. Some tactics (namely the typeclass-variant of eauto if
I'm not mistaken) had to be handwritten to do so.
Still, in the current trunk, there is a whole new engine which treats
evar instanciation and backtracking correctly, so that we could imagine
to have a nicer eauto. The problem is that there is a huge quantity of
legacy code which needs to be ported to the new engine, requiring a lot
of manpower in this process, precisely what we're lacking of. If you
need some given primitives, you can add them using ML code...
PMP
Thanks for the response. I did see the new "+" backtracking branching operator in the trunk, but haven't tried it yet. Does that allow backtracking over solved subgoals in order to alleviate this problem with evars? Also, I didn't notice the typeclass-variant of eauto in the truck - where is that?
About the legacy code porting problem - are you implying that all Coq users will eventually be impacted by a change in eauto itself, or is the "legacy code" you're referring to instead Coq implementation code that will need conversion?
I have never tried writing ML primitives for Coq. I do recall seeing some small amount of documentation on how to do that somewhere - I don't recall where. Do you know where that documentation is?
Sorry for asking so many questions! And thanks again.
-- Jonathan
