- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] dependent destruction without axioms
- Date: Sun, 20 Apr 2014 11:49:24 -0400
Thanks for that tip.
Somehow, my head hurts while writing down such matches manually,
specially for more complicated proofs about more complicated dependent data structures.
It feels like wasting a large fraction of my time and proof-script-space on steps that should intuitively be "trivial".
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Sun, Apr 20, 2014 at 11:20 AM, Daniel Schepler <dschepler AT gmail.com> wrote:
Here's a trick that can avoid the need to derive UIP_refl for a certain type:
Require Import Vector.
Lemma vectorS_decomp : forall {A:Type} {n:nat}
(v : Vector.t A (S n)),
exists (h:A) (t:Vector.t A n), Vector.cons _ h _ t = v.
Proof.
intros.
Require Import Program.
dependent destruction v.
eexists; eexists; reflexivity.
Qed.
Print Assumptions vectorS_decomp.
This shows JMeq_eq being used. But if, instead, you write out:
Lemma vectorS_decomp' : forall {A:Type} {n:nat}
Proof.
intros.
refine (match v as v' in (Vector.t _ Sn) return
(match Sn return (Vector.t _ Sn -> Prop) with
| 0 => fun _ => True
| S n' => fun v'' =>
exists (h:A) (t:Vector.t A n'), cons _ h _ t = v''
end v') with
| Vector.nil => _
| Vector.cons h _ t => _
end); clear n v.
trivial.
Qed.
Print Assumptions vectorS_decomp'.
then this doesn't use JMeq_eq. Lots more examples of this kind of
thing at http://coq.inria.fr/cocorico/EqualityFreeInversion .
I've seen reports on this list that there's an "invert" tactic to be
incorporated in future Coq releases, which should handle doing this
kind of thing automatically.
Daniel Schepler
On Sun, Apr 20, 2014 at 8:00 AM, Abhishek Anand
<abhishek.anand.iitg AT gmail.com> wrote:
> Is there a version of the dependent destruction tactic
> that does not use the JMeq_eq axiom?
> Section 10.5 of CPDT says that JMeq_eq is derivable
> from UIP_refl.
> Also, UIP_refl is derivable for types with decidable equality.
> http://coq.inria.fr/distrib/8.4/stdlib/Coq.Logic.Eqdep_dec.html
> A version of dependent destruction could either take the equality decider
> explicitly as input, or appeal to a designated hint database
> to get the required proofs of decidable equality.
> If someone has already written such a tactic and can share the code,
> I'd be grateful.
> Thanks,
> -- Abhishek
- [Coq-Club] dependent destruction without axioms, Abhishek Anand, 04/20/2014
- Re: [Coq-Club] dependent destruction without axioms, Daniel Schepler, 04/20/2014
- Re: [Coq-Club] dependent destruction without axioms, Abhishek Anand, 04/20/2014
- Re: [Coq-Club] dependent destruction without axioms, Matthieu Sozeau, 04/21/2014
