- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] external proof of termination
- Date: Fri, 25 Apr 2014 23:12:21 +0200
On 25/04/2014 19:45, Kirill Taran wrote:
Didn't know about ConstructiveEpsilon module. Thanks for example.
But why will your example not compute? I don't see any axiom usage there.
This is not related to axioms. The lack of axioms tells you that the existence of f' is consistent; it does not tell you that (f' some_x) will reduce to a value of Y different from (f' some_x).
The rule of thumb is that, whenever Coq needs to perform a step of computation, it has to consume a constructor from a term somewhere. If there are no constructor left to consume, Coq will stop reducing things. So, as soon as you have some opaque definitions around, e.g. the termination lemma, Coq is cut off from its sources of constructors and it stops computing.
But that is not an issue, you just need to artificially introduce sufficiently many constructors. The attached example shows how to do it. It adds 2^64 constructors, which should guarantee that your computer will break down before Coq runs out off constructors.
There is a small test at the end that shows the difference between the version that does not compute and the one that does.
Best regards,
Guillaume
PS: Do not try to "Print" the f' function. There seems to be a bug in Coq that causes it to display garbage. What you see is definitely not how f' is defined; what you see is not even well-typed. (I hope it is only a display issue.)
Require Import Arith Omega. Section computable. Variable Y : Type. Variable f : nat -> option Y. Definition not_yet n := match f n with Some _ => False | _ => True end. Inductive Acc' (n : nat) : Prop := Acc'_intro : (not_yet n -> Acc' (S n)) -> Acc' n. Definition f' : forall n, Acc' n -> Y. Proof. fix 2. intros n []. unfold not_yet. destruct (f n) as [y|]. intros _. exact y. intros H. apply (f' (S n) (H I)). Defined. Hypothesis termination : exists n, forall m, n <= m -> not (not_yet m). Lemma wf : forall k, Acc' k. Proof. destruct termination as [n Ht]. intros k. destruct (le_or_lt n k) as [Hk|Hk]. apply Acc'_intro. intros Hk'. elim (Ht k Hk Hk'). replace k with (n - (n - k)) by omega. cut (n - k <= n). 2: omega. clear Hk. generalize (n - k). clear k. intros k. induction k as [|k IHk]. intros _. rewrite <- minus_n_O. apply Acc'_intro. intros Hn. elim (Ht n (le_n n) Hn). intros Hk. apply Acc'_intro. intros _. rewrite minus_Sn_m with (1 := Hk). apply IHk. apply le_trans with (2 := Hk). apply le_n_Sn. Qed. Fixpoint fuel (n : nat) (acc : forall k, Acc' k) : forall k, Acc' k := match n with | 0 => acc | S n => fun k => Acc'_intro k (fun _ => fuel n (fuel n acc) (S k)) end. Definition not_fueled := f' 0 (wf 0). Definition fueled := f' 0 (fuel 64 wf 0). End computable. Section test. Definition odouble (x n : nat) := match x - n with O => Some (x+x) | _ => None end. Lemma double_termination : forall x, exists n, forall m, n <= m -> not (not_yet nat (odouble x) m). Proof. intros x. exists x. intros m Hm. unfold not_yet, odouble. replace (x - m) with 0 by omega. intros []. Qed. Definition double' (x : nat) := not_fueled _ _ (double_termination x). Definition double (x : nat) := fueled _ _ (double_termination x). Eval compute in (double' 20). Eval compute in (double 20). End test.
- Re: [Coq-Club] external proof of termination, (continued)
- Re: [Coq-Club] external proof of termination, Arnaud Spiwack, 04/28/2014
- Re: [Coq-Club] external proof of termination, Eddy Westbrook, 04/25/2014
- Re: [Coq-Club] external proof of termination, Kirill Taran, 04/25/2014
- Re: [Coq-Club] external proof of termination, gallais, 04/28/2014
- Re: [Coq-Club] external proof of termination, Guillaume Melquiond, 04/25/2014
- Re: [Coq-Club] external proof of termination, Adam Chlipala, 04/25/2014
- Re: [Coq-Club] external proof of termination, Kirill Taran, 04/26/2014
