- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Prod(Type,Type,Type) inference rule question
- Date: Mon, 5 May 2014 11:49:48 -0700
Requiring k to be greater than or equal to both i and j is just another way
to say that k must be at least the maximum of i and j. The idea here is that
(unless B is a Prop, where you can use impredicativity) in order to form a
type forall (a:A), B, you need to go to a universe that is at least big
enough (high enough i) to contain both A and B. If k were less than the
universe level i for A, then k wouldn’t be big enough to even get A, let
alone to get forall (a:A), B.
Hope that helps,
-Eddy
On May 3, 2014, at 2:44 AM, Matej Kosik
<5764c029b688c1c0d24a2e97cd764f AT gmail.com>
wrote:
> Dear all,
> While I was trying to grok the Coq inference rules (as stated in the
> Coq'Art book), I came across this:
> (pages 91,92)
> E,Γ ⊢ A : Type(i) E,Γ ∷ (a:A) ⊢ B : Type(j) i ≤ k j ≤ k
> Prod ────────────────────────────────────────────────────────────────
> E,Γ ⊢ ∀ a:A,B : Type(k)
> Here I started to wonder, what are the reasons for the stated constraints:
> i ≤ k
> j ≤ k
> Why (any) weaker condition, such as
> k ≤ i
> k ≤ j
> , could cause problems?
> I either failed to deduce it from what I know (possible),
> or there is something important I do not know (likely) :-)
> Thanks in advance for any help.
- [Coq-Club] Prod(Type,Type,Type) inference rule question, Matej Kosik, 05/03/2014
- Re: [Coq-Club] Prod(Type,Type,Type) inference rule question, AUGER Cédric, 05/03/2014
- Re: [Coq-Club] Prod(Type,Type,Type) inference rule question, Eddy Westbrook, 05/05/2014
