coq-club - Re: [Coq-Club] need help automating solutions of goals with evars
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] need help automating solutions of goals with evars
  • Date: Fri, 09 May 2014 08:04:32 -0400
You might not like this answer, buuuut: I'd just say "it's a delicate art." You need to understand your domain well enough to introduce all new hypotheses before the evars that will mention them. FWIW, I don't find this to be too challenging in general; it's just something you need to keep in mind while writing tactics and not try to go back and add as an afterthought.
If you send the list a more specific scenario description, we might be able to offer more specific advice.
On 05/08/2014 09:50 PM, Jonathan wrote:
Suppose one has a goal where the consequent contains an evar. It seems that Coq will only allow that evar to be instantiated by hypotheses that existed at the "birth" of that evar - the ancestral goal in the proof tree where the evar was first introduced. Otherwise, Coq produces an error with a message like 'cannot instantiate "?42" because "H" is not in its scope'.
With automation based on pattern matching, the automation might not be able to identify the need for the hypothesis that properly instantiates the evar until a later goal in the proof. But, at that point, Coq won't allow the instantiation.
When proving by hand - one can then undo back to just before the "birth" of the evar and introduce the hypothesis there, then roll forward and do the instantiation. But, how can this be handled with proof automation?
