- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] complex refine usage
- Date: Mon, 12 May 2014 10:13:50 +0200
Quick reply: for dependent subgoals, you can try the trunk.
Goal False.
Proof.
refine (let x:=(_:~~False) in _).
(* 2 subgoals: |- ~~False x:=?4:~~False |- False *)
Proof.
On 11 May 2014 15:51, Kirill Taran <kirill.t256 AT gmail.com> wrote:
Also, finally I succeed with my initial problem.
Brief plot of my solution:Definition complex_function : C -> C. (* "context" of my function body *) refine (Fix my_order_wf (fun _ => C) (fun x (call : forall y, y <<< x -> C) => match x as x_ return (x = x_) -> C with | ... => fun xEq => match x' as x'_ return (x' = x'_) -> C with | ... => fun x'Eq => _ end eq_refl end eq_refl )); (* some bindings instead of "let" in code *) pose (x' := ...); (* proof of correctness for first call: *) assert (call_1 : x' <<< x) by (...). pose (x'' := call ... call_1); destruct ... as ... eqn:...; assert (call_2 : ... <<< x) by (...); pose (x''' := call ... call_2); destruct ... as ... eqn:...; refine (* result *). Qed.In fact it very resembles imperative programming:
"small" steps of manual assigning of values to variables, destructing, etc.
mixed with some "big" steps of refine.
Convoy pattern is used inside first "big" step for providing "context",
because I think it would be too dirty to refine manually Fix part (with pose and destruct).Sincerely,
Kirill TaranOn Sun, May 11, 2014 at 4:39 PM, Kirill Taran <kirill.t256 AT gmail.com> wrote:Hello Dmitry,
Thanks for reference to convoy pattern, I forgot about it.
As for first part of question, in my particular case things are more complex,
so it is pretty difficult to do everything by hands, so I looked for automated
way to do it (something like "dependent refine" tactic).Sincerely,
Kirill TaranOn Sun, May 11, 2014 at 2:48 PM, Dmitry Grebeniuk <gdsfh1 AT gmail.com> wrote:Hello.
Parameter X Y : Prop.
> So, I want to have proof of subgoal 1 when I prove subgoal 2. Is it
> possible?
Parameter callx : X -> bool.
Parameter cally : Y -> bool.
Example first : bool.
refine (andb (callx _) (cally _)).
(* here Coq focuses on goal X *)
Admitted.
Example second : bool.
refine (let y := _ in andb (callx _) (cally y)).
(* here Coq lets me construct term of type Y *)
admit. (* pretend we've constructed it *)
(* here:
1 subgoal
y : Y
_____________(1/1)
X
There is one problem left: even if one takes concrete
X, Y, and provide real value, it won't be present in
hypotheses. There'll be "y : nat" (for example), but
without value, unlike when "pose (y := 123)" is issued.
Here you can use "convoy pattern" described in CPDT.
> For example, when I prove subgoals I need to have hypothesis
> which is result of pattern matching, e.g. that x = S x', but I haven't it.
- [Coq-Club] complex refine usage, Kirill Taran, 05/11/2014
- Re: [Coq-Club] complex refine usage, Dmitry Grebeniuk, 05/11/2014
- Re: [Coq-Club] complex refine usage, Kirill Taran, 05/11/2014
- Re: [Coq-Club] complex refine usage, Arnaud Spiwack, 05/12/2014
- Re: [Coq-Club] complex refine usage, Kirill Taran, 05/13/2014
