coq-club - Re: [Coq-Club] eauto succeeds but typeclasses eauto with core fails
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] eauto succeeds but typeclasses eauto with core fails
  • Date: Thu, 15 May 2014 14:18:06 -0400
On 05/15/2014 12:44 PM, Jonathan wrote:
I have been experimenting (in the trunk version) with the "typeclasses eauto with core" tactic as a fully-backtracking alternative to eauto. However, there are cases where eauto solves a goal but typeclasses eauto with core fails. Some of these cases are quite trivial, such as applying a single constructor when the goal inductive type has a Constructors hint (which is visible in Print Hint output), where that constructor completely solves the goal.
Is it ever supposed to be the case that typeclasses eauto with core fails when eauto succeeds at solving a goal, or is that a potential bug with typeclasses eauto with core? If this is expected behavior, is there a way to use typeclasses eauto with core, or something similar that does full backtracking over evars, so that it is at least as powerful as normal eauto?
-- Jonathan
Upon further experimentation, the problem appears to be due to the presence of type aliases.
This might be related to bug 2920: Type class resolution breaks under aliasing - although it doesn't fail with a "please report" error message, it just prevents typeclasses eauto from succeeding. I'll file a bug report...
-- Jonathan
