- To: coq-club AT inria.fr
- Cc: marcus.ramos AT univasf.edu.br
- Subject: Re: [Coq-Club] Record tutorial
- Date: Fri, 16 May 2014 02:24:57 +0200
Le Thu, 15 May 2014 23:23:49 +0200,
Marcus Ramos
<marcus.ramos AT univasf.edu.br>
a écrit :
> Hi,
> Can anyone suggest me a good tutorial on "Record" (definition, usage
> and examples)?
> Thanks in advance,
> Marcus.
What do you expect to learn on "Record"?
I find this request a little strange, as I am pretty sure that Record
is almost the same thing as Inductive with the following tweaks:
- automatic generation of projections
- alternative syntax for builder
I do not remember if the notations and the 'let' definitions inside of
records are documented, beside that, I really do not see much to say
on records (unlike "Class" which is internally a record, but has other
interesting features record does not have).
Note that the system sadly does not allow you to define recursive
records, so do not expect to define things like:
Record tree := Node
{ index : Type;
subtrees : index -> tree
or
Record nlist (A : Type) := N
{ head : A;
tail : tlist
with tlist (A : Type) :=
| TNil : tlist A
| TCons : nlist À -> tlist A.
- [Coq-Club] Record tutorial, Marcus Ramos, 05/15/2014
- Re: [Coq-Club] Record tutorial, AUGER Cédric, 05/16/2014
- Re: [Coq-Club] Record tutorial, Arnaud Spiwack, 05/16/2014
