coq-club - Re: [Coq-Club] Coq and Computer Algebra System
  • To: Coq Club <coq-club AT inria.fr>, Maxime Dénès <mail AT maximedenes.fr>
  • Subject: Re: [Coq-Club] Coq and Computer Algebra System
  • Date: Fri, 23 May 2014 21:22:00 +0200
CoqEAL - The Coq Effective Algebra Library
http://www.maximedenes.fr/content/coqeal-coq-effective-algebra-library
On Fri, May 23, 2014 at 9:08 PM, David MENTRÉ
<dmentre AT linux-france.org>
wrote:
> Hello,
> 2014-05-23 20:21, Daniel Schepler:
>> I've toyed with the idea of starting a project for a formally verified
>> Computer Algebra System. One of my high-level design goals would be
>> to make all the functionality accessible directly through Coq, in
>> addition to the more conventional "command line" type interface, in
>> order to be able to extract "proofs by reflection".
> Isn't it what is doing Georges Gonthier and his team in Coq/SSReflect?
>> I don't know that much about how existing CASes are structured,
> For Axiom: a Common Lisp base system, then two layers of home made
> languages, then a ton of libraries with cyclic dependencies (you need Axiom
> to compile Axiom, like a compiler).
> But Tim Daly (lead Axiom developer) would probably tell you that the real
> difficulty is not to build the core CAS, it is to build the ton of libraries
> needed for real mathematical work. Axiom was developed over more than 30
> years at IBM.
> If you really want to continue this path, you should probably contact Tim
> Daly. He was interested in formally verified CAS.
> Best regards,
> david
