coq-club - Re: [Coq-Club] Coq and Computer Algebra System
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Coq and Computer Algebra System
  • Date: Sun, 25 May 2014 21:25:50 +0200
Another related work is the contribution "Maple":
http://coq.inria.fr/V8.2pl1/contribs/MapleMode.html
Regards,
Julien Narboux
2014-05-23 21:30 GMT+02:00 Daniel Schepler <dschepler AT gmail.com>:
Some interesting pointers, thanks.  As I indicated, I wasn't all that
serious about the idea as I'd have to do it in my spare time, and I
was fairly certain that wouldn't get me very far starting from
scratch.  I'm glad to see there are some serious projects out there
along these lines, though.
Daniel Schepler
On Fri, May 23, 2014 at 12:22 PM, Catalin Hritcu
<catalin.hritcu AT gmail.com> wrote:
> CoqEAL - The Coq Effective Algebra Library
> http://www.maximedenes.fr/content/coqeal-coq-effective-algebra-library
> On Fri, May 23, 2014 at 9:08 PM, David MENTRÉ <dmentre AT linux-france.org> wrote:
>> Hello,
>> 2014-05-23 20:21, Daniel Schepler:
>>> I've toyed with the idea of starting a project for a formally verified
>>> Computer Algebra System.  One of my high-level design goals would be
>>> to make all the functionality accessible directly through Coq, in
>>> addition to the more conventional "command line" type interface, in
>>> order to be able to extract "proofs by reflection".
>> Isn't it what is doing Georges Gonthier and his team in Coq/SSReflect?
>>> I don't know that much about how existing CASes are structured,
>> For Axiom: a Common Lisp base system, then two layers of home made
>> languages, then a ton of libraries with cyclic dependencies (you need Axiom
>> to compile Axiom, like a compiler).
>> But Tim Daly (lead Axiom developer) would probably tell you that the real
>> difficulty is not to build the core CAS, it is to build the ton of libraries
>> needed for real mathematical work. Axiom was developed over more than 30
>> years at IBM.
>> If you really want to continue this path, you should probably contact Tim
>> Daly. He was interested in formally verified CAS.
>> Best regards,
>> david
