- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite question
- Date: Fri, 30 May 2014 16:15:47 -0400
On 05/30/2014 02:19 PM, Marcus Ramos wrote:
Hi,
I must be missing something quite obvious, but right now I can´t see why
rewrite doesn´t work in the current subgoal (see below). As I can see, the
right hand side of H3 matches exactly a subterm in the goal. Any help will
be appreciated.
CONTEXT+SUBGOALS:
2 subgoal
g : cfg
s2 : sf (g_clo g)
s3 : sf (g_clo g)
s' : sf (g_clo g)
s'' : sf g
H1 : derives (g_clo g) [inl (Start_clo g)] s'
H2 : derives g [inl (start_symbol g)] s''
H : derives (g_clo g) [inl (Start_clo g)] (s2 ++ inl (Start_clo g) :: s3)
H3 : s2 ++ inl (Start_clo g) :: s3 = s' ++ map (g_clo_sf_lift g) s''
H0 : g_clo_rules g (Start_clo g)
[inl (Start_clo g); inl (Transf_clo g (start_symbol g))]
______________________________________(1/2)
In (inl (Start_clo g)) (s' ++ map (g_clo_sf_lift g) s'')
Does it work to use the "pattern" tactic to factor out that term in the consequent?
-- Jonathan
- [Coq-Club] Rewrite question, Marcus Ramos, 05/30/2014
- Re: [Coq-Club] Rewrite question, J. Ian Johnson, 05/30/2014
- Re: [Coq-Club] Rewrite question, Jonathan, 05/30/2014
- Re: [Coq-Club] Rewrite question, plastyx, 05/31/2014
