- To: coq-club AT inria.fr
- Subject: [Coq-Club] Adding a parameter to a definition
- Date: Sun, 1 Jun 2014 09:06:05 -0400
Hi,
Here is my issue. I want to add a parameter to a definition D. Adding
that parameter means that I will have to thread it through many definitions
and lemmas spanning over several files.
Is there some simple way to do that that does not involve updating each
and every definition and lemma that depends on D?
For example, is there a way to get the effect of wrapping
BTW, while testing a few things, I realized that modules are not allowed
inside sections. Why is that?
- [Coq-Club] Adding a parameter to a definition, vincent rahli, 06/01/2014
- Re: [Coq-Club] Adding a parameter to a definition, Cedric Auger, 06/02/2014
- Re: [Coq-Club] Adding a parameter to a definition, vincent rahli, 06/02/2014
