coq-club - Re: [Coq-Club] Prod(Type,Type,Type) inference rule question
  • From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
  • To: Coq Club <coq-club AT inria.fr>
  • Cc: AUGER Cédric <sedrikov AT gmail.com>, Eddy Westbrook <westbrook AT kestrel.edu>
  • Subject: Re: [Coq-Club] Prod(Type,Type,Type) inference rule question
  • Date: Mon, 9 Jun 2014 09:22:21 +0200
    Girard paradox was formulated within certain version of certain Per Martin-Löf axiomatic system.
    It is cited, but for me it is not trivial to judge whether I really reading the right version of that system. Not fine.
The relevant type system is "Type:Type". It is has two type formation rules:
Γ,A:Type ⊢ B:Type
Γ ⊢ Πx:A.B : Type
Γ ⊢ Type:Type
The original Girard's paradox was on an apparently weaker system called system U that had two different sorts.
The problem is similar to that in set theory: type which are too self-referential don't work well.
The essence of the problem is the liar paradox: we can't have an entity which can truthfully claim "I'm a liar" (the self reference is clear here). The Russell paradox quite literally constructs such a liar. The Burali-Forti paradox is a prior version which constructs a set of all the ordinals (which are equivalence classes of well-orderings and are, themselves, well-ordered). The set of the ordinals happens to be an ordinal, so it belongs to itself, but this isn't possible because it contradicts well-ordering.
Both paradox can be adapted in Type:Type but the Burali-Forti paradox is more direct (for the Russell Paradox see Alexandre Miquel's PhD thesis, he builds an encoding of a ZF-style type theory in which the Russel paradox can be written).
From this point of view, I almost got it, but not quite.
It is non-obvious why universes has to form total order.
They don't need to, actually. But if it helps, you can safely assume they do for the sake of the argument.
/Arnaud
