coq-club - [Coq-Club] For arguments of a Class' projections to be explicit
  • From: "Xavier Montillet" <xavierm02.net AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] For arguments of a Class' projections to be explicit
  • Date: Thu, 19 Jun 2014 13:12:21 +0200
Hi,
Since I have/want to use relations over quotient sets, I defined
Class relationA := mkRelationA {
R : relation A;
R_compat :> Proper (eqA ==> eqA ==> iff) R
I currently use "RA.(@R)" to get the "relation A" from the "relationA" but I'd
prefer to force the arguments of the projections to be explicit because weird
things happen.
For example, given two variables:
Variable RA1 : relationA.
Varaible RA2 : relationA.
You can try to prove that their R-projections are equal:
Lemma wut : RA1.(@) = RA2.(@).
And the goal will be "R = R".
Obviously, "reflexivity" doesn't work and one can use "unfold R" to change the
goal to "(let (R0, _) := RA1 in R0) = (let (R0, _) := RA2 in R0)". But I'd
rather not have two different things with the same name in the first place...
So my questions are:
- Is it possible to force the arguments of the projections to be explicit?
- If it is, how?
- If it isn't, would it be possible to use a Record instead but still have
R_compat be "magically registered" so that I can use "rewrite" instead of
"apply R_compat"?
Thank you in advance for your answers.
Respectfully,
Xavier Montillet
