coq-club - Re: [Coq-Club] Extraction fails
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Extraction fails
  • Date: Thu, 26 Jun 2014 18:46:26 -0400
On 06/26/2014 06:23 PM, Christoph-Simon Senjak wrote:
Hello.
I am trying to extract a term from my (very long) code, and I get the
error message
Error: The 2nd argument of exist still occurs after extraction.
Please check the Extraction Implicit declarations.
(How) can I find out what part of my program causes the problem?
I don't think there is any way to find out why an Extraction Implicit declaration fails. And it certainly can fail in non-obvious ways.
As my coding style is very similar everywhere, there will probably many
instances of the same problem (the same error already occured on other
functions I tested). Is it - instead - possible to just extract
everything, including Prop-Terms, so it does not have to bother about these?
Are you suggesting that this failure occurs even when you don't have any "Extraction Implicit" declarations? If not, just remove the "Extraction Implicit" declarations and retry the extraction.
I have a project which uses extraction, and works around the inability of "Extraction Implicit" to deal with certain issues - collectively referred to as erasability. If you are interested: https://github.com/jonleivent/mindless-coding.
-- Jonathan
