coq-club - Re: [Coq-Club] Ltac match to a partial match expression - How does this work in general?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ltac match to a partial match expression - How does this work in general?
  • Date: Sun, 29 Jun 2014 19:28:19 +0200
Dear Jacques-Henri,
my first reaction when I read your answer was: ok I did look so much at the
trees, that I couldn't see the forst any more (as we say in German). But
thinking a bit more about it, it is not so clear to me why this works. My
assumption was that the LTAC match does a match against the syntax tree of the
proof language. But this doesn't seem to be the case. Is the match statement
handled in a special way? How about matching a if then else if then else if
then else sequence? Assume I want to match all the if conditions against a
certain pattern, and don't know at which position it occurs? Can I use a
similar trick?
I couldn't find a documentation for the exact behaviour of the ltac match in
the reference manual.
Thanks & best regards,
Michael
