- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] tricky ltac example
- Date: Wed, 02 Jul 2014 00:49:33 +0200
Ltac matching is not up to delta, you should do something like
match eval hnf in xs with
end
You can change hnf to another evaluation strategy that may be more suitable for your case.
On 07/02/2014 12:43 AM, Kirill Taran wrote:
Hello,
I am implementing a tricky tactic with match on "regular" values.
Match works ok for inlined values, but fails on values binded to a variable.
Here is minimized example:
Ltac matching xs tac :=
match xs with
| cons ?X ?XS => idtac "cons"
| nil => idtac "nil"
end.
Goal 2 + 1 = 3.
(* works: *)
matching (cons 1 (cons 2 (@nil nat))) show.
(* doesn't: *)
Definition l : list nat :=
cons 1 (cons 2 (cons 3 (@nil nat))).
matching l show.
Qed.
Error is "No matching clauses for match".
Sincerely,
Kirill Taran
- [Coq-Club] tricky ltac example, Kirill Taran, 07/02/2014
- Re: [Coq-Club] tricky ltac example, Robbert Krebbers, 07/02/2014
- Re: [Coq-Club] tricky ltac example, Kirill Taran, 07/02/2014
