- To: coq-club AT inria.fr
- Subject: [Coq-Club] Proving efficient decidability of a Prop?
- Date: Wed, 09 Jul 2014 22:54:39 +0200
Hello all!
So I’ve been working on a project and finally proved a particular relation is
decidable:
Theorem MyRel_dec : forall (a:A) (b:B),
{MyRel a b} + {~MyRel a b}.
Proof.
Defined.
The proof is ~220 lines and hinges primarily on well_founded_induction on the
weight of the arguments.
I had thought I would be able to use this theorem to automatically solve MyRel
proof obligations as they come up with no problems using something like this:
Ltac solve_it :=
match goal with
| |- MyRel ?a ?b =>
let provability := constr:(MyRel_dec a b) in
let proof := eval compute in provability in
match proof with
| left ?prf => exact prf
| right _ => idtac
end
end.
However, this takes an inordinate amount of time on all but the most trivial
of examples. (I let one example I thought was simple enough spin for an hour
before aborting)
It seems that although I have proven that MyRel is decidable, I built quite
possibly the absolute worst function for producing witnesses of the MyRel-
validity of potential arguments.
My question is, was it silly of me to think that a big proof of decidability
would be useful in helping prove particular instances? Is there some other
"obviously better" approach I should have taken? Or an obviously better way to
now prove instances of MyRel? Is this the kind of problem where one must
utilize the refine tactic to get correct *and* efficient code? Or is it
possible that I just wrote a particularly bad proof?
Thanks,
Andrew
- [Coq-Club] Proving efficient decidability of a Prop?, Andrew Kent, 07/09/2014
- Re: [Coq-Club] Proving efficient decidability of a Prop?, Pierre-Marie Pédrot, 07/09/2014
- Re: [Coq-Club] Proving efficient decidability of a Prop?, Daniel Schepler, 07/10/2014
- Re: [Coq-Club] Proving efficient decidability of a Prop?, Andrew Kent, 07/10/2014
- Re: [Coq-Club] Proving efficient decidability of a Prop?, Cedric Auger, 07/10/2014
