- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] a question about 'rewrite' tactic
- Date: Fri, 11 Jul 2014 09:51:03 -0400
On 07/11/2014 04:51 AM, Matthieu Sozeau wrote:
Hi,
your confusion is natural, the semantics of “rewrite H at n” are
a bit weird. It will rewrite the nth occurrence of the _first matching lhs_
of H. In this example:
H : forall n : nat, 1 * n = n
n : nat
n + n = 2 * n
the first matching occurrence (for rewrite <- H) is (n + n) (it’s
leftmost-outermost
first for “at”, as is setoid_rewrite). So [rewrite <- H at 2] fails because
there
are no other occurrences of [n + n]. On the other hand, [setoid_rewrite <- H
at n]
will take the nth occurrence of the rhs of H (a unification variable ?n), and
there are 8 possible occurrences in that case.
Hope this helps,
— Matthieu
[Sorry for my left-right confusion! Uh ... I was probably thinking of "instantiate" which numbers from the right.].
This is even more confusing. I thought that vanilla "rewrite" is supposed to fall back on "setoid_rewrite" in non-Leibniz cases. Does that mean that how it follows "at" changes? Or, does the top-level tactic determine how "at" is followed?
-- Jonathan
- [Coq-Club] a question about 'rewrite' tactic, Matej Kosik, 07/10/2014
- Re: [Coq-Club] a question about 'rewrite' tactic, Jonathan, 07/10/2014
- Re: [Coq-Club] a question about 'rewrite' tactic, Matej Kosik, 07/11/2014
- Re: [Coq-Club] a question about 'rewrite' tactic, Cedric Auger, 07/11/2014
- Re: [Coq-Club] a question about 'rewrite' tactic, Matthieu Sozeau, 07/11/2014
- Re: [Coq-Club] a question about 'rewrite' tactic, Jonathan, 07/11/2014
