- To: coq-club AT inria.fr
- Subject: [Coq-Club] Ltac match on quantified hypothesis
- Date: Mon, 21 Jul 2014 10:26:40 +0200
Dear Coq users,
I have another question on ltac matching. Please have a look at the samples
below. My main question is why ?a doesn't match with the 2nd hypothesis in the
second sample NOK1 as it does in the first sample OK1. I assumed that n
remains unbound in the first unification of ?a, so that ?a stiil matches with
the second hyopthesis with a specific value for n (m).
What does work is OK2, where I first match with another free variable ?c and
sort out things later, but when I have several hypothesis, the search effort
increases exponentially with the number of hypothesis.
Another thing I don't understand is why NOK2 doesn't work. The only thing I
changed is the form of the assert.
Thanks & best regards,
Michael
Parameter f g : nat -> Prop.
(* If the quantization applies to both hyopthesis, matching variable ?a twice
works *)
Lemma TestOK1: forall n, (f(n) -> g(n)) -> f(n) -> g(n).
Proof.
intros n Ha Hb.
match goal with
H1 : ?a -> ?b, H2 : ?a |- _ => idtac H1 H2; assert( b ) by ( apply ( H1
H2 ) )
end.
(* If the quantizations are separate, it doesn't work. Why is n not left
unbound in ?a ? *)
Lemma TestNOK1: ( forall n, (f(n) -> g(n)) ) -> forall m, f(m) -> g(m).
Proof.
intros Ha m Hb.
match goal with
H1 : forall n, ?a -> ?b, H2 : ?a |- _ => idtac H1 H2
end.
(* Matching by a different variable ?c and checking if it matches later works,
but this can be inefficient, if several hypothesis need to be matched *)
Lemma TestOK2: ( forall n, (f(n) -> g(n)) ) -> forall m, f(m) -> g(m).
Proof.
intros Ha m Hb.
match goal with
H1 : forall n, ?a -> ?b, H2 : ?c |- _ => idtac H1 H2; assert( AH:= H1 _
H2 )
end.
(* Also why does assert( AH:= H1 _ H2 ) in OK2 work, but not an assert by: *)
Lemma TestNOK2: ( forall n, (f(n) -> g(n)) ) -> forall m, f(m) -> g(m).
Proof.
intros Ha m Hb.
match goal with
H1 : forall n, ?a -> ?b, H2 : ?c |- _ => idtac H1 H2; assert( b ) by
( apply (H1 _ H2) )
end.
- [Coq-Club] Ltac match on quantified hypothesis, michael.soegtrop, 07/21/2014
- Re: [Coq-Club] Ltac match on quantified hypothesis, Beta Ziliani, 07/21/2014
- RE: [Coq-Club] Ltac match on quantified hypothesis, Soegtrop, Michael, 07/21/2014
- RE: [Coq-Club] Ltac match on quantified hypothesis, Beta Ziliani, 07/22/2014
- Re: [Coq-Club] Ltac match on quantified hypothesis, Arnaud Spiwack, 07/22/2014
- RE: [Coq-Club] Ltac match on quantified hypothesis, Soegtrop, Michael, 07/22/2014
