coq-club - Re: [Coq-Club] Reasoning about operational semantics in Prolog
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Reasoning about operational semantics in Prolog
  • Date: Tue, 22 Jul 2014 00:30:22 -0400
Thanks for your interest and offer to help!
The code is available on GitHub, at https://github.com/saraswat/ClockedX10Sem
This program is under a 1000 lines, with the semantics (in x10.pl) in pure Prolog. (The test harness around it has some impure features, but we don't need to reason about it.)
I have just extracted a core program, smallx10.pl (enclosed), which is about 250 lines of code and contains the basic operational semantics (and the definition of the happens before relation) we need to reason about.
Tested with SWI-Prolog.
On 7/21/14, 3:01 PM, David Pichardie wrote:
Dear Vijay,
Prolog definition can generally be translated into inductive predicate in Coq.
If you show me a (small) example, I can show you the corresponding Coq
definition.
I presume you have a huge Prolog program, but writing a compiler may not be
that difficult.
Your project on X10 looks exciting, let me know if me expertise can help.
David
Le 18 juil. 2014 à 13:46, Vijay Saraswat
<vijay AT saraswat.org>
a écrit :
Pardon this newbie question .. would much appreciate pointers!
I have an SOS style semantics for a concurrent language (X10), written up in
(pure) Prolog.
Now need to prove various properties of the semantics, quantifying over all
programs. The properties relate (as usual) structural properties of the code
(e.g. the happens before relation on statements in the program) to the
operational properties (e.g. the sequence of labels in a transition sequence
of the program).
Obviously, a virtue of writing the semantics in Prolog is that one can
exhaustively enumerate all possible transition sequences for (small) X10
programs, and show whether the desired relationship holds or not.
But what we really want is to prove these properties for all X10 programs :-).
Are there existing libraries in Coq which can help reason about pure Prolog
programs? Or will I need to rewrite the semantics in Coq...?
Best,
Vijay
 *  This file is part of the X10 project (http://x10-lang.org).
 *  This file is licensed to You under the Eclipse Public License (EPL);
 *  You may not use this file except in compliance with the License.
 *  You may obtain a copy of the License at
 *      http://www.opensource.org/licenses/eclipse-1.0.php
 *  (C) Copyright IBM Corporation 2014.
 * Based on initial code from Paul Feautrier.
  Simplified version of the semantics in x10.pl.
:-module(smallx10, [
% 1000 xfy ,
	     op(998, xfy, ';'),  % tighter than a ,; represents sequential comp
	     op(997, xfy, '=>'),  % one step reduction operator
	     op(997, xfy, '==>'), % big step, execute to termination operator
	     op(995, fy, clocked), % tighter than ;
	     op(995, fy, finish),
	     op(995, fy, async),
	     op(994, fy, local), % introduces a new local variable
	     op(994, fy, assert),
% 990 xfx :=
             op(750, yfx, '&'),
             op(700, xfx, '<<'),  % lexicographic order
             op(700, xfx, hb0),
             op(300, xfy, '@'),  % annotations
             op(100, yf, []),
	     '=>'/2,
	     '==>'/2,
	     isSync/1,
	     isAsync/1,
             path/3,
	     isClockedStuck/1,
	     hasYield/2,
	     hb/3
:-use_module(library(assoc)).
  annStmt(+S,?SS) :- SS is S with each substatement
  annotated with the path from the root.
  Need to do this in the original statement, since
  paths will change as the statement evolves.
  The term P@S represents sub-statement S annotated with path P
  from the root.
annStmt(S, SS) :- annStmt(S, nil, SS).
annStmt(advance,          P, P@advance).
annStmt(skip,             P, P@skip).
annStmt(local E,          P, P@(local E)).
annStmt(L[I]=R,           P, P@(L[I]=R)).
annStmt(clocked async S,  P, P@(clocked async SS)) :- app(P, ca:nil, PP), annStmt(S, PP, SS).
annStmt((S;T), P, P@(SS;TT)) :-
   app(P, 0:nil, P0), annStmt(S, P0, SS),
   app(P, 1:nil, P1), annStmt(T, P1, TT).
annStmt(for(X, L, U, S),  P, P@for(X, L, U, SS))   :- app(P, X:nil,  PP), annStmt(S, PP, SS).
annStmt(async          S, P, P@(async SS))         :- app(P, a:nil,  PP), annStmt(S, PP, SS).
annStmt(finish         S, P, P@(finish SS))        :- app(P, f:nil,  PP), annStmt(S, PP, SS).
annStmt(clocked finish S, P, P@(clocked finish SS)):- app(P, cf:nil, PP), annStmt(S, PP, SS).
/** path(+S, ?P, ?T) :-
     T is the substatement of S reached by following
     path P from the root. On backtrackng enumerates
     all paths P (and the associated T).
path(advance,           nil, advance).
path(skip,              nil, skip).
path(local E,           nil, local E).
path(L[I]=R,            nil, L[I]=R).
path((S;_),             0:P, U):- path(S, P, U).
path((_;S),             1:P, U):- path(S, P, U).
path(for(X, _L, _U, S), X:P, U):- path(S, P, U).
path(async S,           a:P, U):- path(S, P, U).
path(finish S,          f:P, U):- path(S, P, U).
path(clocked finish S, cf:P, U):- path(S, P, U).
path(clocked async  S, ca:P, U):- path(S, P, U).
%%%%%%%%%%%% The HB Relations %%%%%%%%%%
  +S << +T :-
    S is lexicographically before T.
0:_ << 1:_.
A:S << A:T :- S << T.
    cft(+S, ?T) :-
     S = T K U or T, where T is a sequence in {0,1,ca}*, K is
     cf or f, and U is any sequence.
    (The name is taken from the pattern c f t in the PPoPP paper
     where c stands for a seq in {0,1}*, f is the finish
     and t is any sequence. For clocked programs, clocked finish
     is also a finish, so it has to be treated the same as f. ca's
     are also ok, i.e. the same as 0 or 1, because we use phase
     counts to account for termination of substatements of ca's.)
  cft(S):- cft(S, _).
  cft(nil, nil).
  cft(f:_, nil).
  cft(cf:_, nil).
  cft(0:S, 0:T):- cft(S, T).
  cft(1:S, 1:T):- cft(S, T).
 The hb relation on paths from PPoPP '13 (for unclocked programs),
 extended to handle clocked programs. hb for clocked programs
 uses hb0.
0:S hb0 1:_ :- cft(S).
A:S hb0 A:T :- S hb0 T.
  not_cfs(nil).
  not_cfs(X:S) :- not_cf(X), not_cfs(S).
  not_cf(0).
  not_cf(1).
  not_cf(a).
  not_cf(f).
  not_cf(ca).
  ints(nil).
  ints(0:S):- ints(S).
  ints(1:S):- ints(S).
  app(nil, X, X).
  app(X:S, T, X:U):- app(S, T, U).
  ints_app(   S,    T, U) :- app(S, T, U), ints(T).
  last_cf(S, cf:T, U) :- app(S, cf:T, U), not_cfs(T).
  strict_before(0:nil, 1:_).
  strict_before(A:S, A:T):- strict_before(S,T).
    R (= Alpha cf BO B1) is the path to an advance in S that is
    within the same clocked finish scope as Alpha cf B
    (the target statement whose phase we are trying to
    determine) and that will execute before Alpha cf B.
    For this we need B0 to be a strictly before prefix of B,
    and we need the remainder B1 to be just a sequence of 0's and 1's.
  advanceBefore(S, Alpha, B, R):-
    path(S, R, advance),    % gen all possible R's in S
    app(Alpha, cf:B0B1, R), % they must have an alpha prefix: TODO fold this into the gen
    strict_before(B0, B),
    ints_app(B0, _, B0B1).
   phi(+S, +P, +Alpha, +PreB, ?N, ?Z) :-
   the statement instance P = Alpha cf PreB of S is in controlled by
   a cf at path Alpha, and P has phase N on the Alpha clock. Z is
   the first symbol in PreB after B.
   <p>S must be a loop free program (no for-loops permitted).
   P must be a legal path in it. N is computed to be the phase
   in which S(P) starts.
   <p>This measures  # advances of the Alpha clock executed by
   activity A0 before it executes S(P)
   + #advances of the Alpha clock executed by the clocked activity A1
   that spawned A0 (before it spawned A0),
   + #advances executed by the clocked activity A2 that
     spawned A1 (before it spawned A1), ... all the way up to the
   controlling clocked finish. An adjustment of 0.1 is made if S(P) is
   an advance controlled by the cf at S(Alpha). This permits the
   phase number of the advance at the end of a phase to be strictly greater
   than the phase number of statements executed in that phase.
phi(S, P, Alpha, PreB, N, Z) :-
    alphaCFPrefix(PreB, B, Z),
    (bagof(R, advanceBefore(S, Alpha, B, R), Rs); Rs=[]),
    length(Rs, N1),
    path(S, P, SP), adjustPath(SP, PreB, N1, N).
adjustPath(advance, Pre, M1, M):- not_cfs(Pre), M is M1+0.1.
adjustPath(advance, Pre, M, M):- \+(not_cfs(Pre)).
adjustPath(X, _Pre, M, M) :- X \== advance.
  alphaCFPrefix(nil,  nil, nil).
  alphaCFPrefix(f:_,  nil, nil).
  alphaCFPrefix(cf:_, nil, cf).
  alphaCFPrefix(a:_,  nil, a).
  alphaCFPrefix(0:S,  0:T, Z):- alphaCFPrefix(S, T, Z).
  alphaCFPrefix(1:S,  1:T, Z):- alphaCFPrefix(S, T, Z).
  alphaCFPrefix(ca:S,ca:T, Z):- alphaCFPrefix(S, T, Z).
hb(+S, +P, +Q):-
  This predicate defines the static happens before relationship
  between substatement instances (at P and Q) of a statement S.
  S must be loop free.
hb(S, P, Q) :-
  % let Alpha cf be the common prefix of P and Q, with
  % cf the innermost common clock within which
  % P and Q lie. Fail if there is no such cf.
  app(Alpha, cf:PreBP, P),
  app(Alpha, cf:PreBQ, Q),
  ok(PreBP, PreBQ),
  phi(S, Q, Alpha, PreBQ, N, _),
  phi(S, P, Alpha, PreBP, M, Z), Z \==a,
  M < N.
hb(_, P, Q) :- P hb0 Q.
ok(0:A,   0:B):- ok(A, B).
ok(1:A,   1:B):- ok(A, B).
ok(ca:A, ca:B):- ok(A, B).
ok(a:A,   a:B):- ok(A, B).
ok(f:A,   f:B):- ok(A, B).
ok(nil,     _).
ok(_,     nil).
ok(X:_,   Y:_):- X \== Y.
%%%%%%%%%%%% End of The HB Relations %%%%%%%%%%
%%%%%%%%%%%% The dynamic semantics, ==> and => %%%%%%%%%%
Substitution
 substitute(+Term, +Var, +Val, ?Term1) :- Term1 is obtained from Term by subtituting Val for Var.
substitute(P@A, X, V, P@AA):- substitute(A, X, V, AA).
substitute(A,               _X, _V, A)  :- integer(A).
substitute(A,                A,  V, V)  :- atom(A).
substitute(A,                X, _V, A)  :- atom(A), A \== X.
substitute(local E,         _X, _V, local E).
substitute(async A,          X,  V, async AA)         :- substitute(A,X,V,AA).
substitute(finish A,         X,  V, finish AA)        :- substitute(A,X,V,AA).
substitute(clocked async A,  X,  V, clocked async AA) :- substitute(A,X,V,AA).
substitute(clocked finish A, X,  V, clocked finish AA):- substitute(A,X,V,AA).
substitute((A;B),            X,  V, (AA;BB))          :- substitute(A,X,V,AA), substitute(B,X,V,BB).
substitute(L[I]=R,           X,  V, L[II]=RR)         :- substitute(I,X,V,II), substitute(R,X,V,RR).
substitute([A|B],            X,  V, [AA|BB])          :- substitute(A,X,V,AA), substitute(B,X,V,BB).
Lemma: For all S s.t. stmt(S)
(a) isAsync(S) terminates
(b) isSync(S) terminates
(c) isAsync(S) xor isSync(S)
<p> Being isAsync means that if this statement S is in a composition S;T,
then T can get started. Note in particular that for S;T to be
async, both S and T have to be async. E.g. B=async(A);x=3 is not
async since in {B;C} B has to execute (the substatement x=3) before
C can be activated.
isAsync(_@S):- isAsync(S).
isAsync(async _X).
isAsync((clocked async _S)).
isAsync((S;T))             :- isAsync(S), isAsync(T).
isAsync(for(_X,_E1,_E2,S)) :- isAsync(S).
The rules for isSync(S) follow from isAsync(S) and the desired properties of
isAsync(S) and isSync(S).
isSync(_@S):- isSync(S).
isSync(skip).
isSync(advance).
isSync(_L[_I]=_R).
isSync(local _S).
isSync(finish _S).
isSync(clocked finish _S).
isSync(for(_X,_E1,_E2,S)) :- isSync(S).
isSync(S;_T) :- isSync(S).
isSync(_T;S) :- isSync(S).
/* isClockedStuck(S, C) :- S is the body of a clocked finish statement that is
   stuck, waiting for the clock to advance. C is true iff there is at least
   one activity registered on the implicit clock, waiting to advance. Here it is
   worth noting that isClockedStuck(clocked finish async S, true) should fail since
   the main activity (the body of clocked finish) has spawned an async S, reached the
   end of the block in the body of the clocked finish, and deregistered itself
   from the implicit clock. Hence, indeed, there is no activity registered on the
   clock.
   <p>Note that a clockedStuck statement cannot contain a nested
   clocked finish scope... all such scopes must terminate first
   (hence, disappear).  Hence a clocked finish _S is not, recursively,
   stuck.
   <p> Similarly, if isClockedStuck(S), then S cannot contain a nested
   finish F that is not itself within an async child of S. (Otherwise
   F is being executed by an activity registered on the clock, and must
   complete, i.e. disappear, before the clock can advance.)
  <p>Hence no clauses for
  isClockedStuck(skip, _) :-
  isClockedStuck(local E, _) :-
  isClockedStuck(_A[_B]=_C, _) :-
  isClockedStuck(for(...), _) :-
  isClockedStuck(clocked finish _S, _) :-
  isClockedStuck(finish _S, _) :-
isClockedStuck(S) :- hasYield(S, _, true).
  hasYield(S,T) holds if S isClockedStuck, and the yield of S is T,
  where the yield of S is defined by taking every clocked async substatement
  of S (that is not itself nested in a clocked finish substatement of S) --
  such a statement must have advance as its only activated statement, and taking
 the residual of such clocked asyncs, i.e. the statements in the sequential
 continuation of the advance.
%hasYield(S, T):- clockedStmt(S), isClockedStuck(S, true), yield(S,T).
hasYield(S, T) :- hasYield(S, T, true).
hasYield(P@advance, P@skip, true).
hasYield(P@(clocked async S), P@(clocked async T), C) :- hasYield(S,T, C).
hasYield(P@(S;T), P@(SS; T), C) :- isSync(S), hasYield(S,SS, C).
hasYield(P@(S;T), P@(SS;TT), C) :- isAsync(S), hasYield(S,SS, C1), hasYield(T,TT, C2), or(C1, C2, C).
hasYield(P@(async S), P@(async S), false).
The big step rule.
S ==> label(HH,Ps) :- annStmt(S, SS), store(H), reduce(c(SS, H), t(HH), Ps).
reduce(c(S, H), t(HH),  P:nil) :- c(S, H) => t(HH, P).
reduce(c(S, H), t(HHH), P:Ps)  :- c(S, H) => c(SS,HH, P), reduce(c(SS, HH), t(HHH), Ps).
c(P@skip,               H) => t( H, P).
c(P@(local X),          H) => t(HH, P)   :- empty_assoc(E), update(X, E, H, HH).
c(P@(L[I]=R),           H) => t(HH, P)   :- update(L[I]=R, H, HH).
c(_@(S;T),              H) => c(T, HH, P):- c(S,H) => t(HH, P).
c(_@(S;T),              H) => c(S, HH, P):- isAsync(S), c(T,H) => t(HH, P).
c(_@(async S),          H) => t(HH, P)   :- c(S, H) => t(HH, P).
c(_@(finish S),         H) => t(HH, P)   :- c(S, H) => t(HH, P).
c(P@(for(_X,E1,E2,_S)), H) => t(H,  P)   :- E1 > E2.
c(_@(clocked  async S), H) => t(HH, P)   :- c(S, H) => t(HH, P).
c(_@(clocked finish S), H) => t(HH, P)   :- c(S, H) => t(HH, P).
c(Q@(async S),          H) => c(Q@(async SS),          HH, P)   :- c(S, H) => c(SS, HH, P).
c(Q@(finish S),         H) => c(Q@(finish SS),         HH, P)   :- c(S, H) => c(SS, HH, P).
c(Q@(S;T),              H) => c(Q@(S; TT),             HH, P)   :- isAsync(S), c(T, H) => c(TT, HH, P).
c(Q@(S;T),              H) => c(Q@(SS; T),             HH, P)   :- c(S, H) => c(SS, HH, P).
c(Q@(clocked  async S), H) => c(Q@(clocked  async SS), HH, P)   :- c(S, H) => c(SS, HH, P).
c(Q@(clocked finish S), H) => c(Q@(clocked finish SS), HH, P)   :- c(S, H) => c(SS, HH, P).
c(Q@(clocked finish S), H) => c(Q@(clocked finish T),  H, Q)    :- hasYield(S,T).
c(Q@for(X, E1, E2, S),  H) => c((for(Q,E1)@SS; Q@for(X, EE, E2, S)), H, for(Q)):- % new labels
   E1 =< E2, EE is E1 + 1, substitute(S, X, E1, SS).
/** eval(+T, +Store, ?Val) :-
 evaluate T, using the Store to look up values for variables,
 and return Val.
eval(X, _Store,  X):- number(X); string(X).
eval(X,   Store, Y):- get_assoc(X, Store, Y). % Fails if no value associated
eval(X[I],Store, Y):- eval(X, Store, Xv), eval(I, Store, Iv), get_assoc(Iv, Xv, Y).
store(X):- empty_assoc(X).
update(L[I]=R, H, HH) :- eval(L, H, Lv), eval(I, H, Iv), eval(R, H, Rv), update(L, Lv, Iv, Rv, H, HH).
update(L, Lv, Iv, Rv, H, HH):- put_assoc(Iv, Lv, Rv, Xv1), put_assoc(L, H, Xv1, HH).
update(X, Val, H, HH) :- atom(X), put_assoc(X, H, Val, HH).
Show: for all S, H. clockedStmt(S),  c(S,H)=> c(SS,HH) implies clockedStmt(SS).
Show: for all S, H. clockedStmt(S),  isClockedStuck(S), c(S,H)=> c(SS,HH) implies isClockedStuck(SS).
