- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Inductive definition and induction principle
- Date: Thu, 24 Jul 2014 16:38:00 +0200
Actually, it's more subtle than it may seem:
Conjunction is actually a less polymorphic restriction of cartesian product. We can indeed define the following:
There is a convention of not using the dependent elimination of inductive types in Prop for their elimination principles, even when it would be available. But I don't know why this convention was established in the first place.
/Arnaud
Check (prod:Prop->Prop->Prop).
Definition and_rect' (A B : Prop) (P : A /\ B -> Type)
(f : forall (a : A) (b : B), P (conj a b)) (p : A /\ B) :=
let (x, x0) as p0 return (P p0) := p in
f x x0
Check and_rect'.
(* and_rect'
: forall (A B : Prop) (P : A /\ B -> Type),
(forall (a : A) (b : B), P (conj a b)) -> forall p : A /\ B, P p *)
f x x0
Check and_rect'.
(* and_rect'
/Arnaud
On 24 July 2014 15:56, Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com> wrote:
Hi,
Do you find the fact that "prod_rect" and "and_rect" have different types surprising?
On 24/07/14 14:20, Michel Levy wrote:
> I examine the differences between the and_rect and prod_rect definition (with Print and_rect and Print prod_rect).
> In the and_rect definition, you have P:Type while in the prod_rect definition, you have P: prod A B -> Type.
> Why is the reason of this difference ?
Isn't that just a straightforward consequence of the fact that "prod" and "and" themselves have different types?
That is:
and : Prop -> Prop -> Prop
prod : Type -> Type -> Type
- [Coq-Club] Inductive definition and induction principle, Michel Levy, 07/24/2014
- Re: [Coq-Club] Inductive definition and induction principle, Matej Kosik, 07/24/2014
- Re: [Coq-Club] Inductive definition and induction principle, Arnaud Spiwack, 07/24/2014
