- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Functional Scheme error "cannot define graph(s)"
- Date: Thu, 31 Jul 2014 14:23:18 +0200
This is a bug, it seems to be fixed in trunk.
Meanwhile if you replace curly brackets around {value:Type} by regular
parenthesis it works. Sorry for the inconvenience.
Best regards,
Pierre
2014-07-31 13:44 GMT+02:00 Christopher Ernest Sally
<christopherernestsally AT gmail.com>:
> Hi Pierre
> Sure, I have a tree data type
> Inductive tree {value:Type} : Type :=
> | E : tree
> | N : Info.t → tree → key → value → tree → tree.
> and here's min_elt
> Fixpoint min_elt t : option kvp :=
> match t with
> | E => None
> | N _ E k v _ => Some (k, v)
> | N _ l _ _ _ => min_elt l
> end.
> where kvp := prod key value
> let me peruse the documentation too
> Best
> Chris
> On 31 July 2014 19:33, Pierre Courtieu
> <Pierre.Courtieu AT cnam.fr>
> wrote:
>> Hi,
>> it means that your function is not elligible for functional induction,
>> either because you have a pattern matching that does not follow the
>> discipline described in section 2.3 (Function) or because your
>> function uses higher order too deeply. The error message is explained
>> in Section 2.3 (we should put a link in the section about Functional
>> Scheme).
>> Can you show the definition of min_elt please? It may be easy to fix it.
>> Best regards,
>> Pierre
>> 2014-07-31 5:37 GMT+02:00 Christopher Ernest Sally
>> > Dear Club
>> > When using Functional Scheme (with Induction) what does it mean when the
>> > system says "cannot define graph(s) for ____"
>> > I have some function min_elt and I'm trying to get my principle with the
>> > following
>> >> Functional Scheme min_elt_ind := Induction for min_elt Sort Prop.
>> > Thanks very much.
>> > Warm regards
>> > Chris
- [Coq-Club] Functional Scheme error "cannot define graph(s)", Christopher Ernest Sally, 07/31/2014
- Re: [Coq-Club] Functional Scheme error "cannot define graph(s)", Pierre Courtieu, 07/31/2014
- Re: [Coq-Club] Functional Scheme error "cannot define graph(s)", Christopher Ernest Sally, 07/31/2014
