coq-club - Re: [Coq-Club] How to look up notation definitions?
  • From: Christopher Ernest Sally <christopherernestsally AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How to look up notation definitions?
  • Date: Fri, 1 Aug 2014 12:59:23 +0800
Hmm, not denying Locate's usefulness but doesn't Locate only print out where is symbol is used (which I grant, often does give you what you need)? for example, the other day I wanted to know what ":>" was. Locate ":>". gave
Notation            Scope
"x = y :> A" := eq x y         : type_scope
                      (default interpretation)
"x <> y  :> T" := not (eq x y) : type_scope
which didn't really help (I saw :> in the context of record coercions) and I then had to look it up the "normal" way (which for me is grep-ing the pdf manual).
Best
Chris
On 31 July 2014 15:42, Pierre-Evariste Dagand <pedagand AT gmail.com> wrote:
> is there a good way to look up the definition of a notation or to unfold
> notations in a goal or hypothesis?
"Locate" is your friend:
http://coq.inria.fr/refman/Reference-Manual014.html#hevea_command266
Cheers,
Pierre-Evariste
