- To: coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Proof subtrees under Prop goal: always uninformative?
- Date: Sat, 09 Aug 2014 20:29:32 -0400
Is it true that all goals in a proof subtree that has a Prop root
are uninformative? For example, consider the following:Variable Foo : Set. Coq is preventing case analysis of the ex hypothesis H because the goal Foo is in Set (of course, merely exchanging the constructor and destruct H lines would make things work - but that is besides the point here). However, its parent goal, Bar, is in Prop. Is this simply Coq being overly conservative with case analysis? If not, is there a way for a non-Prop subgoal in a subtree rooted in a Prop goal to impact extraction? -- Jonathan |
- [Coq-Club] Proof subtrees under Prop goal: always uninformative?, Jonathan, 08/10/2014
