- To: coq-club AT inria.fr, Neel Krishnaswami <krishnan AT cs.bham.ac.uk>
- Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] Elimination Rules
- Date: Wed, 13 Aug 2014 11:14:28 +0800
> If you try to formulate the typing rules in the obvious way --- by
> giving mutually-recursive judgements for context well-formedness, type
> and term well-formedness, and equality --- then the definition of the
> type system is clearly structural. However, you will not be able to do
> induction on derivations to prove that weakening is sound, which in
> turn prevents you from being able to show the soundness of
> substitution in any easy way.
What exactly do you mean by "weakening is sound"? As I recall there is no
problem in proving weakening by induction on derivations in Martin-Lof type
theory.
Vladimir.
On Aug 12, 2014, at 8:28 PM, Neel Krishnaswami
wrote:
> On 11/08/14 11:51, Andrej Bauer wrote:> On Sun, Aug 10, 2014 at 10:25 PM,
> Abhishek Anand
> > <abhishek.anand.iitg AT gmail.com>
> > wrote:
> >> The terms (v1:A1 -> B1) and (v2:A2 -> B2) denote equal PI types in Nuprl
> >> iff
> >> A1 and A2 are equal types
> >> and
> >> forall terms a1 and a2 such that a1 and a2 are equal members of A1,
> >> B1[v1\a1] and B2[v2\a2] are equal types.
> > Unless you intend to introduce crazy recursive types this is not a
> > problem: equality on PI_{x:A} B(x) is defined in terms of equality on
> > A and equality on B, where these two equalities have been previously
> > defined. So this is still a fixpoint which uses structural recursion
> > on the structure of a type. Why would you be unhappy with that?
> AFAIK, Nuprl avoids these problems by defining only the universe of
> types and their corresponding PERs recursively, but showing that this
> definition is well-founded requires a surprisingly powerful fixed
> point principle (at least, it surprised me).
> In particular, if you look at Bob Harper's *Constructing Type Systems
> Over an Operational Semantics*, you'll see that he needs the fact that
> a monotone (note: not continuous) function on a CPPO has a least fixed
> point, which is a fixed point principle he establishes by transfinite
> induction and excluded middle. (This is stronger than either the Kleene
> or Knaster-Tarski fixed point theorems.)
> (Martin Escardo and Paul Taylor tell me that Dito Pataraia showed that
> this fixed point theorem also holds in intuitionistic set theory, but
> to my knowledge there isn't a predicative version of it.)
> -- Neel
signature.asc
Description: Message signed with OpenPGP using GPGMail
- Re: [Coq-Club] Elimination Rules, (continued)
- Re: [Coq-Club] Elimination Rules, Terrell, Jeffrey, 08/08/2014
- Re: [Coq-Club] Elimination Rules, Abhishek Anand, 08/08/2014
- Re: [Coq-Club] Elimination Rules, Vladimir Voevodsky, 08/09/2014
- Message not available
- Re: [Coq-Club] Elimination Rules, Abhishek Anand, 08/10/2014
- Re: [Coq-Club] Elimination Rules, Andrej Bauer, 08/11/2014
- Re: [Coq-Club] Elimination Rules, Abhishek Anand, 08/11/2014
- Re: [Coq-Club] Elimination Rules, Neel Krishnaswami, 08/12/2014
- Re: [Coq-Club] Elimination Rules, Andrej Bauer, 08/12/2014
- Re: [Coq-Club] Elimination Rules, Abhishek Anand, 08/12/2014
- Re: [Coq-Club] Elimination Rules, Vladimir Voevodsky, 08/13/2014
