- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Local Canonical Structures instances
- Date: Thu, 14 Aug 2014 14:57:33 +0200
A probably not so helpful and late reply:
AFAIK there is no way to do an instance local. Also AFAIK, when a local variable is generalized at the end of the section, then the instances get generalized too, in your case having the effect of converting the instance local_foo into a "default" instance. A default instance is a "catch all" instance, which in your case triggers because z is a definition, and there is no instance for z.
My 2 late ct.
Best,
Beta
Beta
On Tue, Jul 29, 2014 at 12:48 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
Hi,Is it possible to make a canonical structure instance local? I can't use the [Local] prefix, as I get the error "Error: This command does not support the "Local" prefix.". However, I want to trigger the instance that I have when a projection matches a section variable, and if I leave the instance in, I get unrelated canonical structure failures (and the occasional anomaly), such as the following:Structure foo := { bar : Type; baz : bar }.Canonical Structure foon := {| bar := nat ; baz := 0 |}.Definition qux := nat.Definition z : qux := 0.Check (eq_refl : baz _ = z).Section x.Variable b : Type.Variable p : b.Canonical Structure local_foo (bad : False) := {| bar := b ; baz := p |}.End x.Goal True.pose (eq_refl : baz _ = z). (* Error: Cannot infer an internal placeholder of type "False". *)Thanks,Jason
- Re: [Coq-Club] Local Canonical Structures instances, Beta Ziliani, 08/14/2014
