coq-club - [Coq-Club] Abort-ended test Goals vs. async proof processing
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Abort-ended test Goals vs. async proof processing
  • Date: Sat, 16 Aug 2014 22:53:31 -0400
I just noticed the following behavior: when using asynchronous proof processing, as in Coqide, a goal that ends in Abort won't fully process. As with:
Goal True.
idtac. (*or any one tactic that doesn't fail*)
fail. (*or any sequence of tactics that fails*)
Abort.
Instead of the above goal failing, asynchronous processing mode skips from the first tactic (idtac in this case - which is evaluated) directly to the Abort, seeming to ignore everything in between (it's left colored blue in Coqide, instead of green). No failure occurs.
I don't know if this is the desired behavior of Abort under asynchronous processing mode, but some users might not anticipate such skipping, and might be using Abort-ending goals as tests.
-- Jonathan
