coq-club - [Coq-Club] Rewriting with [pointwise_relation]
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Rewriting with [pointwise_relation]
  • Date: Mon, 18 Aug 2014 15:30:14 +0100
Hi,
Is there a way to rewrite with a hypothesis that whose type is convertible with [pointwise_relation A R f g] without first explicitly changing its type to that?  For example, is there an instance I can add to get the following [setoid_rewrite] to work?
Require Import Coq.Lists.List Coq.Setoids.Setoid Coq.Classes.Morphisms.
Add Parametric Morphism A B : (@map A B)
    with signature (pointwise_relation A (@eq B)) ==> @eq _ ==> @eq _
      as map_eq_mor.
Proof.
  intros x y H ls; hnf in H.
  induction ls; auto; simpl.
  rewrite -> H, -> IHls; reflexivity.
Qed.
Goal forall A B (f g : A -> B) (H : forall x, f x = g x) ls, map f ls = map g ls.
Proof.
  intros.
  setoid_rewrite H. (* Toplevel input, characters 15-31:
Error: Tactic failure:setoid rewrite failed: Nothing to rewrite. *)
Thanks,
Jason
  • [Coq-Club] Rewriting with [pointwise_relation], Jason Gross, 08/18/2014
