coq-club - Re: [Coq-Club] Rewriting with (_ ==> _)%signature
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Rewriting with (_ ==> _)%signature
  • Date: Tue, 19 Aug 2014 10:14:17 +0200
Hi,
you need an additional instance to solve the [subrelation (eq ==> R)
(pointwise_relation A R)]
constraint indeed, which you can declare like so:
Instance eq_sub A (R : relation A) B (R' : relation B) :
Reflexive R -> subrelation (R ==> R')%signature
(pointwise_relation A R')%signature.
Proof. intros Rrefl x y HR u; now apply HR. Defined.
Not all « reasonable » instances like this are defined in the standard
library, for lack of a
general theory of which ones are « canonical » and behave well during proof
search.
Best,
— Matthieu
Le 18 août 2014 à 21:51, Jason Gross
<jasongross9 AT gmail.com>
a écrit :
> Hi,
> I am trying to rewrite with [H : (R ==> S)%signature f g], and Coq doesn't
> seem to want to do this. It seems to be trying to prove that this is a
> subrelation of [pointwise_relation _ S], and failing (regardless of whether
> or not [R] is [Reflexive], or even [eq]). How do I get Coq to allow me to
> rewrite with such things (and why can't it do so already?).
> Here is the relevant code:
> Require Import Coq.Setoids.Setoid Coq.Classes.Morphisms.
> Section foo.
> Context A B (f g : A -> B) (R : relation B) (R' : relation A)
> (H : (@eq _ ==> R)%signature f g)
> (H' : (pointwise_relation _ R) f g)
> (H'' : (R' ==> R)%signature f g)
> `{@Reflexive _ R}
> `{@Transitive _ R}
> `{@Reflexive _ R'}.
> Goal forall x, R (f x) (g x).
> Proof.
> intros.
> Fail setoid_rewrite H. (* Error:
> Tactic failure:setoid rewrite failed: Unable to satisfy the rewriting
> constraints.
> Unable to satisfy the following constraints:
> EVARS:
> ?19==[A B f g R H H' H0 H1 x |- ProperProxy ?17 (g x)]
> (internal placeholder)
> ?18==[A B f g R H H' H0 H1 x (do_subrelation:=do_subrelation)
> |- Proper (?14 ==> ?17 ==> Basics.flip Basics.impl) R]
> ?17==[A B f g R H H' H0 H1 x |- relation B] (internal placeholder)
> ?15==[A B f g R H H' H0 H1 x
> |- subrelation (eq ==> R) (pointwise_relation A ?14)]
> ?14==[A B f g R H H' H0 H1 x |- relation B] (internal placeholder) *)
> setoid_rewrite H'.
> Undo.
> setoid_rewrite H''. (* Toplevel input, characters 0-18:
> Error:
> constraints.
> EVARS:
> ?34==[A B f g R R' H H' H'' H0 H1 H2 x |- ProperProxy ?32 (g x)]
> ?33==[A B f g R R' H H' H'' H0 H1 H2 x (do_subrelation:=do_subrelation)
> |- Proper (?29 ==> ?32 ==> Basics.flip Basics.impl) R]
> ?32==[A B f g R R' H H' H'' H0 H1 H2 x |- relation B] (internal
> placeholder)
> ?30==[A B f g R R' H H' H'' H0 H1 H2 x
> |- subrelation (R' ==> R) (pointwise_relation A ?29)]
> ?29==[A B f g R R' H H' H'' H0 H1 H2 x |- relation B] (internal
> placeholder) *)
> Thanks,
> Jason
