coq-club - Re: [Coq-Club] ssreflect eqtype instance
  • From: "Strub, Pierre-Yves" <pierre-yves AT strub.nu>
  • To: coq-club AT inria.fr
  • Cc: coq-club-request AT inria.fr, Zoe Paraskevopoulou <zoe.paraskevopoulou AT gmail.com>
  • Subject: Re: [Coq-Club] ssreflect eqtype instance
  • Date: Wed, 27 Aug 2014 14:50:57 +0200
Hi,
The ssreflect library already provides subType (in eqtype.v) canonical structure for that case. See for example the definition of n.-tuple (tuple.v) as a subtype of sequences of length n.
Regards,
-- Pierre-Yves.
On 2014-08-27 14:38, Zoe Paraskevopoulou wrote:
Hi,
If you use a decisional procedure to determine if the tree is sorted
you can use proof irrelevance for boolean equality proofs to prove
Equality.axiom.
For example if you define the following
Inductive sorted_tree := SortedTree (t: tree T) (proof: sorted_dec t =
true).
you can have that
forall b, (proof1 proof2: b = true), proof1 = proof2
as a direct corollary of Eqdep_dec.eq_proofs_unicity.
Hope this helps,
Zoe
On Aug 27, 2014, at 12:43 PM, Igor Jirkov wrote:
Hello
Could someone please point me at the explanation of how I can define
eqType for my own types?
About my task: I have defined a type of 'sorted tree' as a pair of
tree and predicate of it being sorted:
Inductive tree (T : Type) : Type := Node : T -> seq (tree T) -> tree
TInductive tree (T : Type) : Type := Node : T -> seq (tree T) ->
tree T
Definition value (t: tree T) : T := match t with | Node v _ => v
end.
Definition children (t: tree T) := match t with | Node _ cs => cs
end.
Fixpoint is_tree_sorted t := match t with
|Node v cs => sorted R (map value cs) && all is_tree_sorted cs
end.
is_tree_sorted t).
Using the same trick as with natural numbers won't work I think
(because there an Equality.axiom is used).
Igor Jirkov
