- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] shelve_unifiable question
- Date: Fri, 29 Aug 2014 13:53:02 -0400
When using all:shelve_unifiable, is it always supposed to shelve all focused goals that correspond to evars in other focused goals?
It seems like all:shelve_unifiable doesn't shelve a dependent evar goal if it was modified (as by renaming a hypothesis within it, or case analyzing a hypothesis within it, or adding a new hypothesis to it, etc.), even though it still corresponds to an evar in other focused goal(s).
I am trying to understand what the expected usage of refine-produced evars and all:shelve_unifiable is supposed to be. I noticed that, when doing case analysis in a goal, it helps if that same case analysis is done simultaneously in its dependent evar goals (this can probably be generalized to: the same antecedent-modifying tactics should be done simultaneously across a goal and all its dependent evar goals). I am guessing that this is the intended expected usage. Is that correct?
If so, an idiom like this forms:
refine (...); shelve_unifiable. (*produce some evars and shelve their goals*)
... (*work in main goal's consequent - finally determine that case analysis of some hyp is needed*)
Unshelve. (*bring the dependent evar goals back in focus*)
all:case ...; intros. (*case analyze similarly across goal and all its dependent goals*)
But, all:shelve_unifiable doesn't do anything following that sequence of tactics, because the dependent evar goals have been modified.
Also: if this idiom is intended, it might be helpful if there was an Unshelve_unifiable command to use above so as not to unshelve goals unrelated to the current focused goals.
-- Jonathan
- [Coq-Club] shelve_unifiable question, Jonathan, 08/29/2014
