coq-club - Re: [Coq-Club] Very long (hopefully not infinite?) Axiom check.
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Very long (hopefully not infinite?) Axiom check.
  • Date: Fri, 5 Sep 2014 17:10:41 +0200
Is there any improvement if you use:
Definition E : @aEn <explicitely put the implicits arguments here> := write_env initial "x"%string Sign.tops.
2014-09-05 15:57 GMT+02:00 Martin Bodin <martin.bodin AT inria.fr>:
Hi again,
I can't say that I really have a minimalistic example, but I found something related (trying to focus more and more on the problematic parts). From what I've understood, this is actually not “Qed”’s guilt, but the general mechanism that adds a term in the environment.
Here is how my code looks like: I first define a dummy environment like the following.
Definition E := write_env initial "x"%string Sign.tops.
This environment is an abstract environment, equipped with a lattice structure: this is why having a close context is difficult… But here is a look at the definition of “write_env”:
Print write_env.
write_env =
fun (E : aEnv) (x : var) (v : aVal) =>
MapDefault.write var aValVar var_OrderedType
  (SumLattice.Lattice aVal (LiftBot.t UnitLattice.t) Sign.LatticeDec
     (LiftBot.Lat UnitLattice.t UnitLattice.Lat)) E x
  (Some (inl v))
     : aEnv -> var -> aVal -> aEn
This definition—using “MapDefault.write” which is at its turn defined using a lot of complex definitions—is I think sufficiently complex to cause problem if Coq wants to unfold it until the end. But Coq accepts this definition without problem.
However the following definition freezes:
Definition test_freezes : forall e, e = E -> True :=
  fun e (_ : e = E) => I.
What is more surprising is that the following axiom definition also freezes:
Axiom test_freezes : forall e, e = E -> True.
This thus seems not to be “Qed”’s guilt, but some computations’s (a normal form computation?) performed after it, when adding a term into Coq's context.
However, the following definition works without problem:
Definition test_doesn_t_freeze : E = write_env initial "x"%string Sign.tops := eq_refl.
Also, the following lemma statement is accepted, and only freezes at the “Qed”:
Lemma test_doesn_t_really_freeze : forall e, e = E -> True.
Proof.
  exact (fun e (_ : e = E) => I).
Qed. (* Freezes at this line, but not at the lemma definition. *)
Did you already heard of such a phenomenon? Is that plausible that the exact cause of my problem is because of some additional computations performed after the definition of an object?
I don't know if that can help, but I'm on Coq 8.4pl2.
I have to admit being really surprised to discover such a thing in Coq, naively thinking that “Axiom” wasn't doing any work other than typing…
Any ideas are welcomed!
Thanks again,
Martin.
And what happens when you are trying:
Definition test : A -> B -> C := fun a => proj1 T.
Does it take a long time ?
Hi,
Yes! It does take the “same” (I didn't see it terminate) amount of time. I thus guess that the “exact” tactic does less work than I thought.
I'm afraid that Gregory Malecha is right: I'll work on a minimalistic example runnable without library… and trying to add explicit types to the problematic terms.
Thanks a lot for your help! I've learned about “Qed” ;-)
Martin.
.../Sedrikov\...
