- From: Christopher Jenkins <cjenkin1 AT trinity.edu>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving List with Concatenation operation is monoid.
- Date: Tue, 9 Sep 2014 10:09:36 -0500
Forgive me if I'm missing something, but if the type signature of list concatenation says it takes two lists and return a list, and Coq is a total language, why would you need to show closure?
On Mon, Sep 8, 2014 at 3:02 AM, Beta Ziliani <beta AT mpi-sws.org> wrote:
On Mon, Sep 8, 2014 at 9:56 AM, mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> wrote:Thank you Beta Ziliani and Casteran Pierre.
On Mon, Sep 8, 2014 at 12:46 PM, Beta Ziliani <beta AT mpi-sws.org> wrote:
> More importantly, Mukesh, you need to know that the very purpose of Coq is
> to check proofs: if it accepted your proof at Qed, then that is a valid
> proof.
> Best,
> Beta
The hesitation was because of I never used exists.
Still, my point is that you shouldn't distrust a proof that Coq accepted after Qed. It doesn't matter which tactics you use for building the proof: if in the end Qed says "X is defined" then X's proof is correct.
> On Mon, Sep 8, 2014 at 9:08 AM, Casteran Pierre <pierre.casteran AT labri.fr>
> wrote:
>> Hi,
>> I think your proof is correct, but too complex.
>> Since list concatenation is already a function (if you use Standard
>> Library's one), you don't need to do a proof by cases.
>> Require Import List.
>> Theorem list_monoid : forall ( X : Type ) ( l1 l2 : list X ), exists (
>> l3 : list X ),
>> l1 ++ l2 = l3.
>> Proof.
>> intros X l1 l2 ; now exists (l1 ++ l2).
>> Qed.
>> Pierre
Right now I am learning Coq from software foundation so no import of
library. Thank you for simple and elegant proof.
-Mukesh Tiwari
>> Le 08/09/2014 08:31, mukesh tiwari a écrit :
>>> intros X l1 l2. destruct l1 as [ | h' l1'].
>>> Case "l1 = nil".
>>> simpl. exists l2. reflexivity.
>>> Case "l1 = cons h' l1'".
>>> simpl. exists ( h' :: l1' ++ l2 ). reflexivity.
Christopher Jenkins
Computer Science 2013
Trinity University
Trinity University
- [Coq-Club] Proving List with Concatenation operation is monoid., mukesh tiwari, 09/08/2014
- Re: [Coq-Club] Proving List with Concatenation operation is monoid., Casteran Pierre, 09/08/2014
- Re: [Coq-Club] Proving List with Concatenation operation is monoid., Beta Ziliani, 09/08/2014
- Re: [Coq-Club] Proving List with Concatenation operation is monoid., mukesh tiwari, 09/08/2014
- Re: [Coq-Club] Proving List with Concatenation operation is monoid., Christopher Jenkins, 09/09/2014
- Re: [Coq-Club] Proving List with Concatenation operation is monoid., Pierre Courtieu, 09/09/2014
