- To: coq club <coq-club AT inria.fr>
- Subject: [Coq-Club] problem with tactic-generated terms
- Date: Fri, 12 Sep 2014 15:10:32 +0300
Hi all,
I'm having trouble implementing even the simplest dependently typed
term using `Fixpoint`, `Definition` etc. I've been doing a lot of
proving using tactics lately and I'm very comfortable with tactics. So
I thought why not define everything using tactics? I came up with
this:
https://gist.github.com/osa1/47ed1dd4267fa379259d
Now before coming to the problem with this, here's a few things: (see
also generated OCaml link in the link above)
* The whole thing looks a bit complex but actually implementing it was
very, very easy. Definitely a lot easier than how it'd be if I wanted
to implement it without tactics.
* Even though generated Coq terms are huge, generated OCaml is
actually very good. It still has some problems though. `snoc` has a
redundant argument which could be eliminated by using OCaml lists for
vectors. First argument of `sum-pairs` is redundant because it's just
vector's length so we could use Vector.t's field instead. Similarly, I
think `pascal_aux`'s first argument may also be removed etc.
So I was actually happy with those definitions. But the problem is I
can't prove even the simplest fact about those definitions. I think
the reason is that `simpl.` no longer works.
First I tried some simple `Eval simpl in ...` commands but none of
them worked. I could compile OCaml files and run what I want just
fine, but in Coq it just doesn't work.
I tried `Eval compute in ...` but it just returned huge terms.
I think because of that I can't prove anything. See my lemma in the
link above. I should expect `simpl.` to make my goal `1 = 1`, but it
just doesn't work.
So I guess I paid the price of using tactics. This is actually very
sad, because 1) I never really understand how to define dependently
typed anything without tactics 2) Using tactics was really fun and
easy.
Now my question is that 1) why Coq can't [simpl] my terms? 2) is there
a way to fix this and make [simpl] working without changing
tactic-based definitions?
I'm also open to all kinds of suggestions on alternative ways of
defining those which allow me to prove stuff.
Thanks,
Ömer Sinan Ağacan
http://osa1.net
- [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Ömer Sinan Ağacan, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Daniel Schepler, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Greg Morrisett, 09/12/2014
- Re: [Coq-Club] problem with tactic-generated terms, Jonathan, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Adam Chlipala, 09/13/2014
- Re: [Coq-Club] problem with tactic-generated terms, Matthieu Sozeau, 09/13/2014
