- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Axioms as typeclasses
- Date: Thu, 18 Sep 2014 15:27:46 -0400
On 09/18/2014 03:11 PM, Daniel Schepler wrote:
I've been toying around with the idea of making the standard
additional axioms into typeclasses. e.g.
Class Classic : Prop :=
classic : forall P:Prop, P \/ ~P.
Class ProofIrrelevance : Prop :=
proof_irrelevance : forall (P:Prop) (p1 p2:P), p1 = p2.
Require ClassicalFacts.
Instance classic_proof_irrel `{Classic} : ProofIrrelevance :=
ClassicalFacts.proof_irrelevance_cci classic.
So this way, if you prove lemma A using just proof_irrelevance, and
then lemma B which uses lemma A and also classic, then you can end up
with lemma B depending only on Classic; whereas with the current Axiom
approach, Print Assumptions B would include both classic and the
redundant proof_irrelevance.
While I have no opinion on this particular issue, I didn't know that Print Assumptions would ever print out something less than the transitive closure of the assumptions in certain cases (as in the typeclasses case you describe). If that's true, is there some way to force Print Assumptions to print out the transitive closure?
Otherwise, for people who are using Print Assumptions as a way to check if inconsistent assumptions are being used together, this could be a problem.
-- Jonathan
- [Coq-Club] Axioms as typeclasses, Daniel Schepler, 09/18/2014
- Re: [Coq-Club] Axioms as typeclasses, Jonathan, 09/18/2014
- Re: [Coq-Club] Axioms as typeclasses, Daniel Schepler, 09/18/2014
