Re: [Coq-Club] is there a rewrite-like tactics that would work for propositions and equivalence?
- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] is there a rewrite-like tactics that would work for propositions and equivalence?
- Date: Sun, 21 Sep 2014 12:03:26 -0400
rewrite can be made to work for other relations.
If you try rewrite H1, the error message will ask you to add the following line above:
Require Coq.Setoids.Setoid.
Then rewrite H1 will do exactly what you wanted.
You can read chapter 3 of the following article to understand how the rewrite functionality can be extended for arbitrary (Prop valued) relations in arbitrary contexts.
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Sun, Sep 21, 2014 at 11:51 AM, Matej Kosik <5764c029b688c1c0d24a2e97cd764f AT gmail.com> wrote:
Hi,
In the standard library (theories/Init/Logic.v), there is this:
Theorem and_cancel_l : forall A B C : Prop,
(B -> A) -> (C -> A) -> ((A /\ B <-> A /\ C) <-> (B <-> C)).
Proof.
intros; tauto.
Qed.
As part of the exercise, I have tried to create a corresponding proof-script without automation.
At one point, I was in this state:
1 subgoal
A : Prop
B : Prop
C : Prop
H1 : B <-> C
______________________________________(1/1)
C /\ A -> B /\ A
and yearned to make the following step:
replace all occurrences of "B" with "C" (this step is justified by "H1 : B <-> C"
and find myself here:
1 subgoal
A : Prop
B : Prop
C : Prop
H1 : B <-> C
C /\ A -> C /\ A
Is there a tactic that would allow me/us to do this kind of step?
(just like as we can take advantage of equalities by "rewrite" tactics.)
- [Coq-Club] is there a rewrite-like tactics that would work for propositions and equivalence?, Matej Kosik, 09/21/2014
- Re: [Coq-Club] is there a rewrite-like tactics that would work for propositions and equivalence?, Abhishek Anand, 09/21/2014
- Re: [Coq-Club] is there a rewrite-like tactics that would work for propositions and equivalence?, Arnaud Spiwack, 09/22/2014
