- From: Richard Dapoigny <richard.dapoigny AT univ-savoie.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Problem with tactic intuition auto
- Date: Mon, 22 Sep 2014 23:34:53 +0200
Le 22/09/2014 16:13, Rui Baptista a
écrit :
(P t) doesn't in general imply (forall x, P x), so if you
can prove (forall B : N, B ε A -> B ε el A) from just (B :
N) and (B ε A → B ε el A), that's because the tactics you used
know something more about ε or el or the variables involved.
I don't understand why you are using [generalize] after
using [assert]. Neither B nor H17 occur in the conclusion.
Doesn't that just copy B and H17 to the conclusion?
What [intuition] in [intuition auto] does is it tries to
break down logical connectives and solve an intuitionistic
propositional calculus problem. Since it doesn't succeed,
[auto] then takes over from there by blindly [apply]-ing up to
a certain depth all combinations of hypotheses and hints in
the database. That search isn't very deep because it has
exponential execution time. You can increase the search depth
by using [auto n], where n is a natural. [auto] is equivalent
to [auto 5]. Also, you can get more info by using [info_auto]
instead of [auto].
Regards
All the best. --
begin:vcard fn:Richard Dapoigny n:Dapoigny;Richard email;internet:richard.dapoigny AT univ-savoie.fr tel;work:+33 450 09 65 29 tel;cell:+33 621 35 31 43 version:2.1 end:vcard
- [Coq-Club] Problem with tactic intuition auto, Richard Dapoigny, 09/22/2014
- Re: [Coq-Club] Problem with tactic intuition auto, Rui Baptista, 09/22/2014
- Re: [Coq-Club] Problem with tactic intuition auto, Richard Dapoigny, 09/22/2014
