- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Partial functions in Coq
- Date: Thu, 25 Sep 2014 18:19:44 +0200
Hi, there are basically to ways of defining partial functions in coq.
The first is with monad None/Some as in Isabelle.
The second is by using dependent types to have a complete function on
a "subset" of the carrier type.
Defining recursive functions on dependent types is generally not
considered easy,
and reasoning about them even less easy. It is however elegant:
Require Import Arith.
Require Import Program.
Require Import Omega.
Parameter y:nat.
(* First define a measure for proving termination*)
Definition minus ij := snd ij - fst ij.
(* Then define a function on a subset of nat*nat using the existential type.
The proof obligations are either for termination or for completing the
dependent type of recursive calls. *)
Program Fixpoint diff (ij:nat*nat | fst ij <= snd ij) {measure (minus
ij)}:nat :=
match beq_nat (fst ij) (snd ij) with
true => 0
| false => diff(fst ij+1,snd ij) + 1
end.
Next Obligation.
simpl in *.
symmetry in Heq_anonymous.
apply beq_nat_false in Heq_anonymous.
omega.
Defined.
Next Obligation.
simpl in *.
unfold minus;simpl.
omega.
Defined.
Lemma foo: fst (1,3) <= snd (1,3).
Proof.
simpl.
repeat constructor.
Defined.
Eval compute in diff (exist _ (1,3) foo).
(* We cannot express the lemma exactly as you did because we cannot
apply diff to (i,j) without a proof that i<=j, it becomes: *)
Lemma L: forall i j, (exists (H:i<=j), diff (exist _ (i,j) H) = i - j)
\/ (exists (H:j<=i), diff (exist _ (j,i) H) = j - i).
(* and I have no time to prove it. Not trivial. *)
Best regards,
Pierre
2014-09-25 17:31 GMT+02:00 Iain Whiteside
<Iain.Whiteside AT newcastle.ac.uk>:
> Dear all,
> I am investigating the ways in which different theorem provers handle
> undefinedness. In Isabelle, for example, 5/0 is represented as some number,
> but we cannot reason about it; alternatively, partial functions can be
> encoded in a monad (None | Some x).
> I’d be interested to hear what is the (if any) canonical way of
> representing partiality in Coq and pCiC? For example, how could a recursive
> difference function like below (deliberately partial) be represented?
> diff (i,j) = if i = y then 0 else diff(i+1,j) + 1
> additionally, could a theorem such as
> forall i j. diff(i,j) = i - j \/ diff(j,i) = j - i
> Many thanks in advance,
> Iain
- [Coq-Club] Partial functions in Coq, Iain Whiteside, 09/25/2014
- Re: [Coq-Club] Partial functions in Coq, Pierre Courtieu, 09/25/2014
- Re: [Coq-Club] Partial functions in Coq, Rui Baptista, 09/26/2014
