- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] where does CoqIDE store its preferences?
- Date: Fri, 26 Sep 2014 11:51:21 -0400
While experimenting with having two git clones of Coq (one set to the head of the trunk, another set to a friendlier point in the past), I inadvertently broke CoqIDE by setting its preferences for coqtop path incorrectly. As a result, I couldn't even start up CoqIDE to change the mistake (luckily the other CoqIDE was startable - and they share preferences).
So I have two questions:
- Where does CoqIDE store those preferences, in case the same thing happens again?
- Is there a way to set the paths for coqtop (and coqc, etc.) in those preferences to be the same as the path to CoqIDE itself? It seems that the only options I currently have are an absolute path, a relative path to the current workdir, or no path (and so use $PATH).
-- Jonathan
- [Coq-Club] where does CoqIDE store its preferences?, Jonathan, 09/26/2014
- Re: [Coq-Club] where does CoqIDE store its preferences?, Victor Porton, 09/26/2014
- Re: [Coq-Club] where does CoqIDE store its preferences?, Jonathan, 09/26/2014
- Re: [Coq-Club] where does CoqIDE store its preferences?, Enrico Tassi, 09/26/2014
