- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Initial working dir in CoqIDE vs. PG
- Date: Sun, 28 Sep 2014 20:25:52 -0400
On 09/28/2014 08:19 PM, Jason Gross wrote:
This sounds reasonable; you should make a bug report/feature request.
-Jason
OK - I'll do that. I just noticed the "enhancement" item on the Severity pulldown menu in the bug reporter...
On Sep 28, 2014 1:06 PM, "Jonathan"
<jonikelee AT gmail.com>
wrote:
Suppose one has a Coq script "pwd.v" that just contains the single line:
Pwd.
When this script is loaded in Proof General, the result printed for the
Pwd command is the path of the directory containing the script, regardless
of the location of emacs or where it was started from.
When this script is loaded in CoqIDE, the result printed for the Pwd
command is the path of the directory where CoqIDE was started from,
regardless of the location of the script.
This makes it difficult to use relative paths within Coq scripts
effectively so that the script has the same behavior whether run in PG or
CoqIDE. For example, a command such as [Add LoadPath "." as Foo.] would
work for development using PG, but usually not for CoqIDE, unless one
somehow arranges for CoqIDE to always be started in the home directory of
the script it is running.
I think it would make sense for CoqIDE to have some way to behave like PG
for such cases. Consider that, quite often, an IDE such as PG or CoqIDE is
started by clicking an icon on the desktop or toolbar, or from a global
application menu. In such cases, the current directory of the IDE at
startup is almost never a good place to use as the current working
directory of a file loaded into that IDE after startup. Certainly it is
possible to arrange for some other single current directory to be
associated with that icon - but that only solves the problem when loading
scripts in that specific directory, not in others.
Would it be possible to add a "-scriptwd" option to CoqIDE to get PG's
behavior?
Or would it make more sense to just change CoqIDE's behavior to mirror
that of PG?
-- Jonathan
- [Coq-Club] Initial working dir in CoqIDE vs. PG, Jonathan, 09/28/2014
- Re: [Coq-Club] Initial working dir in CoqIDE vs. PG, Jason Gross, 09/29/2014
- Re: [Coq-Club] Initial working dir in CoqIDE vs. PG, Jonathan, 09/29/2014
