- From: Arthur Azevedo de Amorim <arthur.aa AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Relation between a Coq proof and decision procedure?
- Date: Mon, 29 Sep 2014 11:36:27 -0400
Yes. Because P hold of all natural numbers, this mapping A is just the
constant function true:
Section Foo.
Variable P : nat -> Prop.
Hypothesis P_is_true : forall n, P n.
Definition A : nat -> bool := fun _ => true.
Lemma l : forall n, A n = true <-> P n.
Proof.
intros n.
split.
- intros _. apply P_is_true.
- reflexivity.
Qed.
End Foo.
2014-09-29 11:31 GMT-04:00 Zhoulai.FU@Gmail
<zhoulai.fu AT gmail.com>:
> Hello,
> I have little background in proof theory. Here is a naive question that I
> am thinking about:
> Let P denote a predicate over natural numbers. Suppose that I have a coq
> proof for "forall n:nat, P(n)”. Then, can I establish a mapping A from
> natural numbers to {true, false}, so that for any natural number n, A(n)
> is true if and only if P(n) can be proved?
> Otherwise, does some weaker guarantee holds for this mapping A, such as
> "for any natural number n, A(n) is true implies P(n) can be proved” ?
> Thank you for your ideas.
> Zhoulai Fu
- [Coq-Club] Relation between a Coq proof and decision procedure?, Zhoulai.FU@Gmail, 09/29/2014
- Re: [Coq-Club] Relation between a Coq proof and decision procedure?, Arthur Azevedo de Amorim, 09/29/2014
- Re: [Coq-Club] Relation between a Coq proof and decision procedure?, John Wiegley, 09/29/2014
- Re: [Coq-Club] Relation between a Coq proof and decision procedure?, Pierre Courtieu, 09/29/2014
- Re: [Coq-Club] Relation between a Coq proof and decision procedure?, Kristopher Micinski, 09/29/2014
