- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How does "rewrite at" work?
- Date: Wed, 01 Oct 2014 11:57:20 -0400
On 10/01/2014 11:38 AM,
michael.soegtrop AT intel.com
wrote:
Dear Coq users,
can someone explain to me how "rewrite at" works? Please have a look at this
simple example:
Require Import NPeano.
Theorem Test1 : forall a b c d:nat, a+b = c+d -> b+a = d+c.
Proof.
intros.
rewrite Plus.plus_comm at 2. Doesn't work
But, "setoid_rewrite Plus.plus_comm at 2." does work. This was brought up in another thread this summer. I think it has to do with vanilla rewrite finding the first target it unifies with ("a+b"), then looking for the 2nd occurrence of that target - which would be another "a+b", not "c+d". But, setoid_rewrite does its occurrence processing prior to final target unification.
It certainly is confusing. And not documented. I think the setoid_rewrite variant of the behavior is more intuitive.
-- Jonathan
rewrite Plus.plus_comm with (m:=c). Does work
I was expecting that rewrite at 2 swaps d+c, but I get an error. rewrite at 1
works as expected. Also "rewrite with" works for the second term.
From the description in the reference manual I was assuming that rewrite at 2
should swap d+c in the above term. I also tried larger numbers (not knowing
how terms are counted), but everything I tried except for 1 doesn't work with
rewrite at.
Best regards,
Michael
- [Coq-Club] How does "rewrite at" work?, michael.soegtrop, 10/01/2014
- Re: [Coq-Club] How does "rewrite at" work?, Jonathan, 10/01/2014
- RE: [Coq-Club] How does "rewrite at" work?, Soegtrop, Michael, 10/02/2014
