- From: Marcus Ramos <marcus.ramos AT univasf.edu.br>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Replace does not work
- Date: Tue, 7 Oct 2014 16:37:51 -0300
Hi,
I can´t see why "replace" does not work in the following case. The context is:
1 subgoals
g : cfg
i : nat
s : sentence
s0 : sf
l : list sf
n : non_terminal
H1 : sflist g (s0 :: [] :: l)
H2 : S i = Datatypes.length (s0 :: [] :: l)
H3 : s0 = [inl n]
H4 : last (s0 :: [] :: l) [] = map terminal_lift s
H5 : s <> []
left : non_terminal
right : sf
s' : sf
H21 : [] = right
H22 : rules g n right
______________________________________(1/1)
exists l' : list sf,
sflist (g_emp g) l' /\
hd [] l' = hd [] (s0 :: [] :: l) /\ last l' [] = last (s0 :: [] :: l) []
I execute "replace (s0 :: [] :: l) with ([s0] ++ ([] :: l)) in H1." and the new context that I get is:
2 subgoal
g : cfg
i : nat
s : sentence
s0 : sf
l : list sf
n : non_terminal
H3 : s0 = [inl n]
H5 : s <> []
left : non_terminal
right : sf
s' : sf
H21 : [] = right
______________________________________(1/2)
______________________________________(2/2)
[s0] ++ [] :: l = s0 :: [] :: l
That is, instead of getting a new H1 (with the replacement required) and a corresponding new subogal, I get the same H1 as before and the new subgoal. "simpl in H1" before "replace" does not work as well. Any suggestions?
Thanks in advance,
Marcus.
- [Coq-Club] Replace does not work, Marcus Ramos, 10/07/2014
- Re: [Coq-Club] Replace does not work, Adam Chlipala, 10/07/2014
- Re: [Coq-Club] Replace does not work, John Wiegley, 10/07/2014
- Re: [Coq-Club] Replace does not work, Marcus Ramos, 10/08/2014
